Odometer mechanism in automobiles.
zaveri
@zaveri-5TD6Sk โ€ข Oct 24, 2024
What exactly is the working principle of the Odometer in autos ?
now i am wondering whether the odometer will deflect, if the vehicle is moved by towing ?
Tagging at experts #-Link-Snipped-# #-Link-Snipped-# #-Link-Snipped-#
    @sarathkumar-FEGRPw • Jul 24, 2013
    Odometer works with there worm gears .The input shaft is connected to the worm and it rotates the gear and similarly gear reduction happens in all there worm gears .The output of the worm gear rotates the odometer's ten's place.This in turn turn the previous place values every ten rotation completion.
    The digital odometers are more accurate and costs less.
    The older models rotate backwards when vehicle is moved backwards.
    @ramani-VR4O43 • Jul 25, 2013
    A flexible shaft transfers the revolutions of the rear (left) wheel of the auto to a further reduction train as CSK described. This is displayed like any water or electricity meter.
    The catch is that if the tire is worn out, the meter will show a longer distance for the same actual distance traveled because the circumference is less.
  • CE Designer
    @ce-designer-BWq0yl • Jul 25, 2013
    I would like some more clarity on this topic. Example, what about all wheel drive cars? Is it the same principle for manual and automatic transmissions? What if the vehicle is towed in neutral with all fours on the ground?
    @sarathkumar-FEGRPw • Jul 25, 2013
    please refer "#-Link-Snipped-# stuff works.com" to know more .
