  • NOx emissions
    mechky
    mechky
    @mechky-jbqpJD
    Updated: Oct 22, 2024
    In general, the theory says that reducing engine temperature reduces NOx emissions.
    Is anyone aware of the temperatures at which NOx is produced in automobile engines(gasoline engines)?
    Please provide some useful information or links.
  • PraveenKumar Purushothaman
    MemberDec 23, 2011
    NOx is generally the result of really high temperature exhaust. I would richen the mixture slightly to lower temperatures, or advance the timing slightly. I think that will cool the engine down enough.
    Moreover, it is formed at higher combustion temperatures, oxygen and nitrogen fuse at temperatures of something like 1400-1600° F and during the rich burn cycle, NOx is reduced. The lean burn cycle converts the hydrocarbon and carbon monoxide emissions. That's why O[sub]2[/sub]S switch between rich and lean, for the catalyst to work properly. The EGR's sole purpose is to reduce this particular gas by actually lowering combustion temperatures, a rich condition is introduced when the EGR is open (exhaust gas is low in oxygen) and thereby creates a rich air / fuel ratio, which reduces cylinder temperatures. A hotter running engine is more efficient but will not reduce NOx emissions, the proper emissions equipment is required for that. A fat tune will reduce NOx but may put you at risk of exceeding HC emissions.
  • mechky
    MemberDec 24, 2011
    Praveen-Kumar
    thanks for confirming the temperature range.....
