netsh interface tcp show global - Command Help
When I run the command prompt in Administrator mode, and execute netsh interface tcp show global, it shows me various settings.
I couldn't find much information about what exactly does the listed parameters do in Vista Operating System [Not sure whether its there in XP].
Anyone's got clue what are those settings for?
  • durga ch
    @durga-TpX3gO • Mar 25, 2010
    Looks like its for configuring interfaces< I cant talk about tcp command as it did not run on my office machine> but the look of it- should mainly be used for viewing and configuring the network interfaces
    Microsoft Windows XP [Version 5.1.2600]
    (C) Copyright 1985-2001 Microsoft Corp.
    C:\Documents and Settings\Vijaya Durga>netsh
    netsh>interface
    netsh interface>show
    The following commands are available:
    Commands inherited from the netsh context:
    show alias - Lists all defined aliases.
    show helper - Lists all the top-level helpers.
    show mode - Shows the current mode.
    Commands in this context:
    show credentials - Shows the credentials used to connect an interface.
    show interface - Displays interfaces.
    netsh interface>show interface
    Admin State State Type Interface Name
    Enabled Dedicated Local Area Connection
    Enabled Dedicated <snipped MAC address >
    Enabled Internal Internal
    Enabled Loopback Loopback
    netsh interface>
    I know This is not of much help , anyone who could use the tcp command or for that matter - can you put up the window results for easier analysis?
