Need some help with Mechanical Engineering and Machining terms
Hi guys, I am a student of the Electrical and Computer department of University of Toronto and I am going through a thesis titled A power assessment of Machining tools by David Kordonowy.
I am new to mechanical engineering and there are a few terms and concepts related to machining (especially CNC machining) that is not at all familiar with, I hope you can help me with some of these.
I already know the general terms such as milling, turning (lathe), material removal rate... which at first I was not very clear on, here are the terms that I need help with:
1. The author used the word "cut" very generally. Is drilling considered "cutting"?
2. What does the terms "loaded" and "unloaded" mean? For example I don't really understand the phase "unloaded hydraulic motor". Does it mean that it is in operation?
3. When does "feeding" occur? And why its unit is defined as (inch/rev) if feed means that the component moves the workpiece linearly?
4. How does the "phase" of a motor defines the property of a motor? What is a 3 phase or single phased motor?
Lastly, there is an odd term called "flute" that is sometimes used in conjunction with "width" therefore becoming flute width. I am not at all clear as to what this maybe I don't know if you could help out.
Thank you in advance!
