Need Help with Internet Problem
Sanyam Khurana
@sanyam-Nl7Zqc β€’ Oct 25, 2024
Hi there !
I'm facing some issues with my net. For like 1.5 day their server was down, now it's up and running, still there are issues.
Some sites are not opening at all (like w3 Schools)
Some sites are loading but without images (CE) {only on some pages}
Some sites are working perfectly (gmail & fb)
My friend recommended me to change dns settings to Open DNS and I changed it to :
DNS : #-Link-Snipped-#
Alternate DNS : #-Link-Snipped-#
Previously, issue was resolved, but now this didn't work.
I talked to my ISP, they say the server is up, and all is fine.
But on my side, things are really messed up. Can anyone help me?
#-Link-Snipped-# can you suggest anything?
    @thebigk Jun 27, 2014
    Pretty simple issue to address, I guess. Your have issues with the DNS server and the best way to fix it up is to update your DNS settings to use Google DNS:
    Use: 8.8.8.8 & 8.8.4.4
    Images on CrazyEngineers are served from Amazon CDN. If Amazon isn't accessible from your locations, the images won't load. Make sure that your settings are working fine. You should be able to find your active DNS address by typing "ipconfig/all" in command prompt.
  • Sanyam Khurana
    @sanyam-Nl7Zqc Jun 27, 2014
    Kaustubh KatdarePretty simple issue to address, I guess. Your have issues with the DNS server and the best way to fix it up is to update your DNS settings to use Google DNS:
    Only images in articles aren't loading, rest all are loading for me, even profile pics are loading fine.
    Nope. Google DNS isn't working πŸ˜”
  • whiz.kid.aniket
    @whizkidaniket-5IiBCq Jun 27, 2014
    Try flushing your dns cache!
  • Sanyam Khurana
    whiz.kid.aniketTry flushing your dns cache!
    Yup, already done long ago, nothing happened. :/
  • whiz.kid.aniket
    Which OS you are using? and Browser?
  • Sanyam Khurana
    whiz.kid.aniketWhich OS you are using? and Browser?
    Both Ubuntu & Win8
    In windows tried on Firefox 30.0, Chrome Version 35.0.1916.153 m, IE.
    In Ubuntu tried on Firefox.
  • whiz.kid.aniket
    Your ISP may be the source of the problem. Try "Obtain DNS server address automatically" setting. It may work.
  • Manish Goyal
    @manish-r2Hoep Jun 27, 2014
    1: What are the results of <a href="https://www.speedtest.net/?" target="_blank" rel="nofollow noopener noreferrer">Speedtest by Ookla - The Global Broadband Speed Test</a>
    2: Do you have any proxy configured on your browser? if so then disable it
  • Sanyam Khurana
    Manish Goyal1: What are the results of <a href="https://www.speedtest.net/?" target="_blank" rel="nofollow noopener noreferrer">Speedtest by Ookla - The Global Broadband Speed Test</a>
    1. Unable to open even speedtest.net πŸ˜”
    But while downloading anything it gives me normal speed I used to get earlier.
    2. Nope. Not using any proxy.
  • Manish Goyal
    ping speedtest.net, if it working, then there is similar discussion going on here, it may help you
    <a href="https://www.sevenforums.com/browsers-mail/41754-browser-not-working-but-internet-connected.html" target="_blank" rel="nofollow noopener noreferrer">Just a moment...</a>
  • Sanyam Khurana
    Manish Goyalping speedtest.net, if it working, then there is similar discussion going on here, it may help you
    Ping is working fine 0% data loss. Reading the discussion.
  • durga ch
    @durga-TpX3gO Jun 27, 2014
    Few basic tests to localise the problem:
    if you are using wifi, try using internet via a LAN cable.
    Also, try accessing internet via other devices to see if you can replicate the problem
    take your laptop to your friends house and see if problem is replicable.
    Also, if you know anyone else who uses same ISP as yours, check with them too.
    That should help you determine where the problem is.
  • Sanyam Khurana
    @sanyam-Nl7Zqc Jun 28, 2014
    durgaFew basic tests to localise the problem:
    Tried on my phone, w3schools not working, and some other sites as on my laptop.
    Nothing happening.. What the hell, I can't even see half of the sites fully. πŸ˜” 😭😭
  • whiz.kid.aniket
    @whizkidaniket-5IiBCq Jun 28, 2014
    I m pretty sure its ISP problem then!
  • Sanyam Khurana
    whiz.kid.aniketI m pretty sure its ISP problem then!
    MTNL service. πŸ˜•πŸ˜‘πŸ˜”πŸ‘Ž
  • Sanyam Khurana
    @sanyam-Nl7Zqc Jul 4, 2014
    This is irritating, after numerous calls, the problem isn't rectified. πŸ˜”
