Need help regarding building a mechanical robot
Hello,
The task that this robot is supposed to perform is: It has to carry some balls and move from the starting line to the finish line, drop the balls there and come back..All without use of any battery. Only by the use of mechanical potential energy(gravitational and elastic).
Here is my idea. I want you to tell me if it is feasible, economical and executable. Or whether I'm idealising things too much..
A mass kept at a height will fall and this is connected to a pulley. Thus, a string is pulled and this string is connected to the axle of the wheel of the robot. Thus the wheel turns and the robot moves forward. The mass falls on one side of a see-saw and the other side contains the box of balls. It will tilt( it is hinged) and all the balls will fall. For the coming back part, I want to use a torsional spring which has already stored energy and upon reaching the finish line, it gets activated and forces the robot to move in the opposite direction.
Please give me suggestions, criticisms. Anything will do.
Thank you, in advance.
YellowSubmarine.
