Need Help: New kind of Matrix formula?
ErAnushka
@eranushka-4BgWe8 โ€ข Oct 26, 2024
In my book, I've:
Problem: Express the matrix [] as a sum of symmetric and skew symmetric matrices.
Okay, as far as I know, symmetric matrix remains the same even if we transpose it.
And the skew symmetric matrix is the same as it's -1 x the transpose of itself.
How do I suppose to solve this?
here [] =
| 2 -4 9 |
| 14 7 13 |
| 3 5 11 |
I think, first I should write the transpose of matrix which is the symmetric matrix and then write the transpose again multiplied by -1.
After that I can add both matrix and prove that it is equal to the [] matrix.
but in book, they used these formula,
B = 1/2 (A+A')
C = 1/2 (A-A')
I'm not sure what is this... and where it came from ๐Ÿ˜จ
Anyone can explain me? My method is right or the method used in the book? โ˜•
  • ErAnushka
    @eranushka-4BgWe8 • Sep 3, 2012
    No problem I got ๐Ÿ˜€
    A direct proof is as follows:
    Let X be the given square matrix
    Let X=A+B where A is symmetric and B is skew symmetric
    That is A'=A and B' = - B .......(1)
    Therefore,
    X'=A'+B' ( using the property of transpose of a matrix)
    or, X'=A - B from (1) above
    Now, as X is square , therefore, X+X' and X-X' are defined.
    Therefore X+X'=A+B +A-B= 2A
    and X-X'=A+B- (A-B) = 2B
    Therefrore A=(X+X')/2
    and B= (X-X')/2
    It is easy to verify that A'=A and B'= - B
    That is A is symmetric and B is skew symmetric
    Therefore , X can be uniquely expressed as sum of a symmetric matrix and a skew symmetric matrix, which is
    X =(X+X')/2 + (X-X')/2
    I understood the green part ๐Ÿ˜€ , but the red part is little confusing๐Ÿ˜• .. A'=A and B' = -B but how? we got only A=(X+X')/2 and B= (X-X')/2.... ??? ๐Ÿ˜จ
  • silverscorpion
    @silverscorpion-iJKtdQ • Sep 4, 2012
    I'm not sure what you are not getting here.. A = A' and B = -B' are assumptions that you made in the beginning, right? (ie., you have assumed that A is symmetric and B is skew symmetric)
    You can probably take the transpose of (X+X')/2 and (X-X')/2, and check that they are indeed the same as A and -B.. but, here it's actually assumed that it is true.
  • ErAnushka
    @eranushka-4BgWe8 • Sep 4, 2012
    silverscorpionI'm not sure what you are not getting here.. A = A' and B = -B' are assumptions that you made in the beginning, right? (ie., you have assumed that A is symmetric and B is skew symmetric)
    Omg wait... I got it ๐Ÿ˜€
    We are actually proving that any square matrix is a sum of symmetric matrix and skew symmetric matrix, so here, A is symmetric matrix and B is skew symmetric matrix.
    We got both value, so,
    A+B = (X+X')/2 + (X-X')/2
    A+B = (X+X' + X-X') /2
    A+B = 2X/2
    A+B = X
    Here X is a square matrix! OMG! I'm so stupid ๐Ÿ˜
    By the by thanks for the reply, I got the idea at the moment of reading this again ๐Ÿ˜€
