need help in using 6mm high speed drill
shahir
@shahir-lswF02 โ€ข Oct 26, 2024
i'm using high speed drill 6mm in diameter to make a hole on S45C/SAE1045 carbon steel. the problem is, i don't know the suitable range of feed and rotation speed of 6mm high speed drill when drill over Hb190 hardness material. Anybody can help me on this drill processing problems..
๐Ÿ˜•
  • raj87verma88
    @raj87verma88-ZpL2Wn • May 14, 2009
    What is the material of the Drill.
  • shahir
    shahir OP
    @shahir-lswF02 • May 14, 2009
    i don't quite know about the material,if is it high speed steel...how would it be?
  • Rifaa
    @rifaa-NaWZZ4 • May 14, 2009
    U know what I do if I am going to drill steel, get a high speed drill bit, hook it up to drill, manual or stand and just drill at high rpm. Simple.
  • shahir
    shahir OP
    nope..im doing it for my research..not for home crafting...tq
  • zorif
    @zorif-NVUQGT • Jun 8, 2009
    HB190...
    you need solid carbide drill them with medium speed.feed iam not sure..give it a try.
