Necessity is the Mother of Invention - Batch Job
Hey CEans,
I would like to share something interesting happened just now, when I wanted to do something! ๐Ÿ˜€ This is one solid proof that if you have the will to do, you will find a way somehow! ๐Ÿ˜€
So, what did I do? I was downloading about 25 files for some work of mine and I had to organise them into folders, under my Downloads folder. Each file has a description in a URL and the file itself has a unique name. Lets consider there are three files for now.
File #1
File:      NetBeans IDE
File Name: netbeans-7.1-ml-php-windows.exe
File URL:  https://netbeans.org/downloads/start.html?platform=windows&lang=en&option=php
File #2
File:      Eclipse IDE
File Name: eclipse-jee-indigo-SR1-win32.zip
File URL:  https://www.eclipse.org/downloads/packages/eclipse-ide-java-ee-developers/indigosr1
File #3
File:      Aptana Studio
File Name: Aptana_Studio_3_Setup_3.0.8.exe
File URL:  https://www.aptana.com/products/studio3/download
Now I want them in a folder structure this way:
/NetBeans IDE
--/netbeans-7.1-ml-php-windows.exe
--/Link.txt (Content: https://netbeans.org/downloads/start.html?platform=windows&lang=en&option=php)
/Eclipse IDE
--/eclipse-jee-indigo-SR1-win32.zip
--/Link.txt (Content: https://www.eclipse.org/downloads/packages/eclipse-ide-java-ee-developers/indigosr1)
/Aptana Studio
--/Aptana_Studio_3_Setup_3.0.8.exe
--/Link.txt (Content: https://www.aptana.com/products/studio3/download)
Could anyone guess what did I do? Remember, there are 25 files! ๐Ÿ˜€ I did it in about 3 minutes!!! ๐Ÿ˜€
  • PraveenKumar Purushothaman
    @praveenkumar-66Ze92 • Feb 6, 2012
    Okay CEans, I just did this. I opened Microsoft Excel and at first, wrote down the URLs and names of the folders. The sheet looked this way:
    | https://netbeans.org/d...dows&lang=en&option=php | NetBeans IDE  |
    | https://www.eclipse.org/d...developers/indigosr1 | Eclipse IDE   |
    | https://www.aptana.com/products/studio3/download | Aptana Studio |
    Then I created the directories for the same using this:
    mkdir NetBeans IDE
    mkdir Eclipse IDE
    mkdir Aptana Studio
    After that I browsed through the Internet to find how am I supposed to create a text file with some contents, using command line. I got this piece of info:
    echo Content > filename
    echo Hello World > New.txt
    This I thought of making use and tried to rearrange the Excel sheet this way:
    | echo | https://netbeans.org/d...dows&lang=en&option=php | > " | NetBeans IDE  | \Link.txt" |
    | echo | https://www.eclipse.org/d...developers/indigosr1 | > " | Eclipse IDE   | \Link.txt" |
    | echo | https://www.aptana.com/products/studio3/download | > " | Aptana Studio | \Link.txt" |
    Yup, I used Excel's good functions like fill, etc., and made this. Then I copied everything to notepad and used Find & Replace and replaced all the Tab characters to spaces and formatted the output. The final batch command was:
    echo https://netbeans.org/d...dows&lang=en&option=php > "NetBeans IDE\Link.txt"
    echo https://www.eclipse.org/d...developers/indigosr1 > "Eclipse IDE\Link.txt"
    echo https://www.aptana.com/products/studio3/download > "Aptana Studio\Link.txt"
    Finally, I copied all the files using the same batch command! ๐Ÿ˜€ It was a pretty awesome experience, isn't it??? ๐Ÿ˜€
    @thebigk • Feb 6, 2012
    That's some Crazy Engineering, Praveen ๐Ÿ‘
  • Dancer_Engineer
    @dancer-engineer-EJ8rGI • Feb 6, 2012
    That's work done awesomely! ๐Ÿ‘
  • KenJackson
    @kenjackson-mBf7HF • Feb 6, 2012
    Yes, that's one of the more novel uses of a spreadsheet that I've seen.
    But I enjoy routinely whipping out scripts to do this sort of thing.
    On Windows I always install <a href="https://cygwin.com" target="_blank" rel="nofollow noopener noreferrer">Cygwin</a> so I have a bash shell.
    And on my preferred Linux platform, the bash shell is native.
    Here's a script that does approximately that, though I'm not sure of the URLs.
    #!/bin/bash
    DIR=("NetBeans IDE"
        "Eclipse IDE"
        "Aptana Studio"
    FILE=("netbeans-7.1-ml-php-windows.exe"
          "eclipse-jee-indigo-SR1-win32.zip"
          "Aptana_Studio_3_Setup_3.0.8.exe"
    URL=(
    "netbeans.org/downloads/start.html?platform=windows&lang=en&option=php"
    "www.eclipse.org/downloads/packages/eclipse-ide-java-ee-developers/indigosr1"
    "www.aptana.com/products/studio3/download"
    for n in $(seq 0 2); do
        dir="${DIR[$n]}"
        file="${FILE[$n]}"
        url="${URL[$n]}"
        cd /tmp                # or ~/Desktop or wherever
        mkdir -p "$dir"
        cd "$dir"
        wget -c "https://$url/$file"
    done
    KenJacksonYes, that's one of the more novel uses of a spreadsheet that I've seen.
    #!/bin/bash
    DIR=("NetBeans IDE"
        "Eclipse IDE"
        "Aptana Studio"
    URL=(
        dir="${DIR[$n]}"
        file="${FILE[$n]}"
        url="${URL[$n]}"
        mkdir -p "$dir"
        cd "$dir"
    done
    Nice one, I thought of this, but I didn't wanna use programming here! ๐Ÿ˜› I just used a Windows Batch file to keep all things right! ๐Ÿ˜€ Simple isn't it??? ๐Ÿ˜€
  • eternalthinker
    @eternalthinker-Kvsi5Y • Feb 6, 2012
    Cool !
    And for future uses, we may code a simple loop which takes content and link as inputs in each iteration ๐Ÿ˜€
    (And create necessary files with the input)
    @praveenkumar-66Ze92 • Feb 7, 2012
    eternalthinkerCool !
    Still wondering if loops work in Batch... I have been testing it for long!!! ๐Ÿ˜›
    @abrakadabra • Feb 7, 2012
    ๐Ÿ˜ฒ whoa! Never thought that could be done. Will try it some time.
    Great sharing CEan praveen. ๐Ÿ‘
  • Sahithi Pallavi
    @sahithi-oJZaYj • Feb 7, 2012
    Simply Awesome! I'll try it out ๐Ÿ˜€
    Praveen, you are really a Crazy Computer Science Engineer ๐Ÿ‘
    Thankz Sada & AKD!!! ๐Ÿ˜
  • Reya
    @reya-SMihdC • Feb 7, 2012
    Thanks for sharing it geeky ๐Ÿ˜€
    ReyaThanks for sharing it geeky ๐Ÿ˜€
    Will share again if I become mad and do something great! ๐Ÿ˜€
