  • priya ts
    @priya-ts-seBH4D • Sep 7, 2012
    ๐ŸŽ‰
  • sauravgoswami
    @sauravgoswami-UAfTlI • Sep 7, 2012
    how about Cheetah - Four Stroke
    Eagle - Two Stroke
  • sweet_honey
    @sweet-honey-areuMs • Sep 8, 2012
    priya tswhy this four stoke & two stroke engines are named like that?๐Ÿ‘Ž
    They are named on the basis of the crankshaft revolution to complete a power cycle by the engine and the no. of strokes of the piston.
    The two stroke engine completes a power cycle in only 1 crankshaft revolution with 2 strokes (up/down movement) of the piston.
    Whereas, the four stroke completes its power cycle in 2 crankshaft revolutions with 4 strokes of the piston.
    The four strokes of a 4 stroke engine are- Suction, Compression, Power and Exhaust.
    But in 2 stroke engine, the end of combustion (or power) stroke and beginning of compression stroke happen simultaneously, performing the intake and exhaust functions at the same time.
  • zaveri
    @zaveri-5TD6Sk • Sep 8, 2012
    to make a long story short:
    four stroke engines: each working cycle is completed in FOUR stokes of the piston.
    two stroke engines: each working cycle is completed in TWO stokes of the piston.
  • Jeffrey Arulraj
    @jeffrey-xA7lUP • Sep 8, 2012
    sauravgoswamihow about Cheetah - Four Stroke
    Eagle - Two Stroke
    the problem is both cheetah and eagle have distinctions of being the fastest in their jurisdiction
  • sauravgoswami
    @sauravgoswami-UAfTlI • Sep 8, 2012
    I just suggested the name ;-) Stoke sounds as if its a medical emergency
  • zaveri
    sauravgoswamiI just suggested the name ;-) Stoke sounds as if its a medical emergency
    "stroke" is more of an affliction, than a surgery. isn't it ?
  • sauravgoswami
    Yeah, it occurs if any of your artery is blocked, disrupting blood flow, which can result in life threathing emergency
    zaveri"stroke" is more of an affliction, than a surgery. isn't it ?
  • Jeffrey Arulraj
    sauravgoswamiYeah, it occurs if any of your artery is blocked, disrupting blood flow, which can result in life threathing emergency
    specially the one to the brain i don't know more about it ๐Ÿ‘
