@anoop-kumar-GDGRCn • Aug 8, 2012
JVM invoked by a its path of <Java-Home>/bin/java.exe./sh or any other.
it your choice which jvm you want to use. -
@rahul69-97fAOs • Aug 17, 2012
I think by default the latest installed JVM is used by the system.
@jalajpachouly-uI3S2X • Aug 19, 2012
You can have as many JVM you want. The program will use the JVM which is indicated in path variable.So it doesn't have any issue if you have even 10 JVM. One thing to remember - you prgoram should be comatible to the JVM which you are using, otherwise it might not work properly.
