Minimize the total area
Banashree Patra
@banashree-patra-m0OJwR • Oct 12, 2024
A piece of wire 16 inches long is cut into two pieces. One piece is bent to form a square and the other is bent to form a circle. Where should the cut be made in order to minimize the total area of the square and the circle?
  • silverscorpion
    @silverscorpion-iJKtdQ Apr 24, 2012
    Let's say the cut is made at a distance 'a' inches from any end..
    Then, we can have the first piece of length 'a' be made into a circle and the other piece of length (16-a) be made into a square. Or, we can have the piece of length a be made into a square and the other into a circle.
    In the first case, we have the total area as
    A = Pi * a[sup]2[/sup] + (16-a)[sup]2[/sup]
    In the second case, it is,
    A = Pi * (16-a)[sup]2[/sup] + a[sup]2[/sup]
    Taking either equation and minimising that equation with respect to a, we have,
    the total area will be minimum when the cut is made at
    a = 16/(1 + Pi) = 3.863 inches
    from one end, or
    a = (16 * Pi)/(1 + Pi) = 12.137 inches
    from the other end..
  • Banashree Patra
    @banashree-patra-m0OJwR Apr 24, 2012
    silverscorpionLet's say the cut is made at a distance 'a' inches from any end..
    from one end, or
    #-Link-Snipped-# you made some silly mistake
    In the first case 'a' is the circumference of the circle.So its radius(r) would be a/(2*pi) and each side(y) of the square would be (16-a)/4
    So the total area=pi*r*r+y*y
    Similarly for second case.
  • silverscorpion
    @silverscorpion-iJKtdQ Apr 25, 2012
    ^^ ahh.. Yes, what a silly mistake indeed 😁
    So, the total area comes to be
    A = a[sup]2[/sup]/4*Pi + (16-a)[sup]2[/sup]/16
    Minimizing this, the value of a seems to be 16*Pi/(4+Pi) or 7.04 inches from one end..
  • Prashanth_p@cchi
    @prashanth-p-at-cchi-rg0z63 May 23, 2012
    I think it has to be exact half. 8 inches each.
    Total area will be (min) = 4inches (square) + approx 5inches (circle) = approx 9 inches (9.09inches).
    Increasing the radius and decreasing the side of a square or the increasing the side of a square and decreasing the radius will result in a value more than ever since squares are involved in the calculation.
    Just take a n example and check for both the cases. I believe that I'm right.
    Let me know if I'm missing something.
    @ramani-VR4O43 May 23, 2012
    SS is right. The 7.04 has to be made into a circle ad 8.96 into a square.
