@jeffrey-xA7lUP • Jun 22, 2013
I am reading your qn wrong I guess
What is your need do you need an inverter ckt? or a Charger Ckt?
Both operate differently and do inverse operation So pls be more clear in your qn -
@ahsan-shafiq-c8AxJj • Jun 22, 2013
i need a circuit which invert 12vdc to 220vac and also charge my 12v battery like a ups -
@arunchary-VtqB3c • Jun 23, 2013
please mention the load such that inverter circuit will be considered ok.a simple ac to dc circuit with more amperes a battery can charged ok.like using lm317,lm350 as a voltage regulators.normal power supply design concept or else for perfect charging concept you need to adopt PWM concept to recharge your lead acid battery. -
@ahsan-shafiq-c8AxJj • Jun 24, 2013
oh thnx. I wanna make 500W ups... U have any ciruit of 500w ups or inverter ? -
@arunchary-VtqB3c • Jun 24, 2013
go for first transformer design then you need to select the Controller based or a simple Ic based inverter ahh. if it so you can find at Rickyes world on net their u can find the simple design of Inverter.if not ill be post on day after tomorrow on CE,because my design is at final state its of 300watt and 500watt inverter. -
#-Link-Snipped-# please follow this link you ill get information... -
@aalandkar-R9Nf1k • Jul 31, 2014
Hello Mate,
I have a doubt. If you have to simply charge laptop battery with a +12VDC battery, you can directly connect them using a series resistance why are you looking for an inverter.?
