  • Morningdot Hablu
    @morningdot-6Xuj4M Aug 1, 2010
    Hello rishi,
    Just like a computer which take the input process them and then give the output.
    Same with microcontroller. It works like a mini computer which take the input process it and then give the output for what you programmed it.
    It's a programmable IC which is programmed generally in assembly language(*.asm) file.A micro controller will act as program it. It also have some inbuilt memory inside.
    Correct me if i am wrong.
    @thebigk Aug 1, 2010
    rishi0922What is Microcontrollers ?
    Example.....
    Refer to any of the electrica/electronics text books and you'll find the answer. You may read the following article on Wikipedia to get an idea -
    <a href="https://en.wikipedia.org/wiki/Microcontroller" target="_blank" rel="noopener noreferrer">Microcontroller</a>
  • bill190
    @bill190-VhqyZT Aug 1, 2010
    Microcontrollers have everything needed in one chip to work by themselves.
    Microprocessor, program memory (firmware), data memory, and peripheral devices like serial communications, USB, timers/counters, etc.
    You will find these in microwaves, washing machines, stereos, refrigerators, electronically controlled tools, automotive electronic modules, etc.
    More...
    <a href="https://en.wikipedia.org/wiki/Microcontroller" target="_blank" rel="nofollow noopener noreferrer">Microcontroller</a>
    <a href="https://en.wikipedia.org/wiki/Parallax_Propeller" target="_blank" rel="nofollow noopener noreferrer">Parallax Propeller</a>
    <a href="https://en.wikipedia.org/wiki/PIC_microcontroller" target="_blank" rel="nofollow noopener noreferrer">Pic Microcontroller</a>
