@thebigk • Aug 11, 2009
Thread moved to here.
Feel free to ask questions and provide as many details you can along with your questions. Be assured that you'll be helped by CEans. -
@tyr-BTjgRw • Aug 11, 2009
thread moved to where??? superblog? -
@debu-62iszV • Aug 11, 2009
using code warrior....
ldy #6000
loop:
dey
bne loop
try embedding this in an outer loop to successively turn an led at port b on and off with a one second period. then embed the wole thing in a continuous loop to run forever.
second
use the led flasher code from the other exercise to build a pulse width modulator. the modulator should read a byte from port h and output a pulse to port b with a period of 256 ms and a duty cycle equal to the value of the byte at port h divided by 256
thanks -
@tyr:
This looks like a homework assignment. Anyway, here:
;Blink LED on 0th bit of PORTB ORG 0xF000 ;Beginning of code stack Start: LDS #0x0C00 ;Load 0x0C00 to the top of the stack CLR COPCTL ;Disable COP by making the COPCTL register 0 BSET PORTB, 0 ;Set bit 0 of PORTBB ;Outer loop outer: ; Your code starts here: ldy #6000 ;Load Y with 6000 loop: dey ;Decrement Y bne loop ;If y!=0 branch to loop ;After wasting 6000 cycles (roughly 1 sec in this case) COM PORTB ;Complement PORTB JMP outer ;Jump to outer ENDNow, you should use my code above to make PWM on your own, its really simple.
Regards,
Debu 😀
