  • Microcontroller Based LPG Gas Leakage Detector using GSM Module.
    Ankit Sood
    Member
    Updated: Oct 26, 2024
    Views: 1.3K
    Project Abstract / Summary : LPG gas is supplied in pressurized steel cylinders. As this gas is
    heavier than air, so when it leaks from a cylinder it flows along floor and tends to settle in low spots such as a basement. This
    can cause fire or suffocation if not dealt with.
    The presence of dangerous LPG leakage in the cars, service station or in the storage tank environment can be detected using the Ideal Gas Sensor which we will be using in our Project.
    This LPG gas leakage detector unit can be easily integrated into a unit that can sound an alarm or give a visual suggestion of the LPG concentration.The sensor has both admirable sensitivity and rapid response time. This sensor can also be used to sense other gases like iso-butane, propane, LNG and even cigarette smoke.
    The output of the sensor goes LOW as soon as the LPG sensor senses any gas leakage from the storage. This is detected by the microcontroller and the LED & buzzer is turned ON. After a delay of few milliseconds, the exhaust fan is also turned ON for throwing the gas out and it continues sending message as ‘GAS LEAKAGE’ to a mobile number which is pre-defined.
    Why did you choose to work on this project topic : I chose to work on this project topic as I am quite interested in working with Microcontrollers. This topic has significance in everyday life as the presence of dangerous LPG Gas Leakage in cars, homes etc. can be detected using an Ideal Gas Sensor which we will be using in this Project. This Project has a lot of future scope in the sense that more facilities for prevention of leakage of LPG Gas could be made available in all residential areas like Hotels, Hospitals, and Industries etc. Also in future the level of LPG gas leakage can be reduced by using Cs2 gas
    which will neutralize the value of LPG gas.
    Institute/College Name: Krishna Institute of Engineering and Technology Ghaziabad
    City: Ghaziabad
    State: Uttar Pradesh
