Micro Hydro Generator Project EEE
Ahsanul haque
@ahsanul-haque-2o7iUb Oct 20, 2024
I have to submit a project on march. please look this video
I am interested about this project :Electricity generator by using rain water. but i have some question in my mind first generator using for electricity generation, it shows the reading in ammeter. but i noticed some some circuit and light, battery, transformer etc. but there is no connection with generator with this circuit, and How can i build generator, can i buy it from local market, or i have to create it. please tell me somethings about this project.
Thanks
remon
  • Jeffrey Arulraj
    @jeffrey-xA7lUP Mar 4, 2014
    Generator get it from a shop Making it is itself a big project
  • Ahsanul haque
    @ahsanul-haque-2o7iUb Mar 4, 2014
    first i have to learn micro generator details ... but need more realistic reply regaarding my topics
  • Jeffrey Arulraj
    Friend Generator works on the same principle as micro generator. Only that the voltage output is lesser nearly 5V ( as per the video) Some are in the range of upto 12V as well.
    The video uses DC voltage generator and so it uses an invertor circuit to convert it into AC.
    One trouble I find is the input given to the transformer is 12V but the power generated by the dynamo is only 3.5V at the maximum. So you will need more than one of the same circuit to run in series to get the required output.
    Try to add a voltage convertor ic like 7809 or 7812 to get a fixed voltage output. Use that output for your wave shaping IC the model is ready
  • Ahsanul haque
    my question was why there using battery, light, and also circuit if we able to generate electricity from generator and turbine, and why there not include those things means light . i want to show others that generated electricity turn on the light.
  • Jeffrey Arulraj
    Generated electricity is used to charge the battery and so directly or indirectly it is running the light.
    The battery is constantly drained at the lamp and it is recharged by the turbine and generator duo.
    You can show to others this by just showing the circuit in operation
  • Ahsanul haque
    @ahsanul-haque-2o7iUb Mar 8, 2014
    Thanks jeffrey try to understand look this video well, there is not connection between ammeter and dynamo/generator.
    I appreciated about your comment. But in this video it showed different views.
  • vamsi kancharla
    @vamsi-kancharla-kL9oxU May 4, 2014
    Ahsanul haqueI have to submit a project on march. please look this video
    Thanks
    remon
    DONT go for dc generator you buy ac motor with less rpm available in the market so that your circuit complexity decreases and you can also maintain speed constant according to your video
