  • Metering on The HT side
    Duppa
    Member
    Updated: Oct 26, 2024
    Views: 1.5K
    Hello,
    I am aware of substations that are with and without metering on the High Voltage side.
    Is anyone aware of any applicable code regarding this? Metering should be compulsory in my opinion, but then I see systems up and running without this.
    Also - another side - Even if metering is done, appropriate control system should be in place. Mere metering is not effective. So what this protection system should be?
    - Duppa
  • Abhishek Havanur
    MemberDec 10, 2016
    Duppa
    Hello,
    - Duppa
    I think CT'S(CURRENT TRANSFORMER) nd PT's (Potential transformers) are there for metering. on HV as well as LV side
  • Duppa
    MemberDec 11, 2016
    I agree with your reply. What kind of protection devices we have to use in case of a 22KV/415V step down transformer - Both on LT side and HT side.
    Current is 1500 Amps...
    Any professional working in the field here....??
    Also can anyone provide me names/links to other forums related to electrical where I can try out my questions.... I know one Electrical Technology...that has been good so far.
  • Abhishek Havanur
    MemberDec 11, 2016
    Duppa
    usually the power lines either HV or LV which are connected to transformers from outside are connected through the "Circuit Breakers" ie.: Vaccum CB, OIL CB, Air Blast, SF6... for inside the transformer there are many differential Protective Relays ....
    If you need more info about protection check out this book : "SWITCH GEAR AND PROTECTION" by JB Gupta or Mehta or U.A.Bakshi, M.V.Bakshi..... and you can go through this "electrical4u.com"
