Mechanical GATE study
I am solving online practice tests for GATE. And in this thread, I will ask my doubts. I am looking for someone who can clarify them. Anyway's we can always discuss all GATE mechanical doubts here.
Member • Jun 21, 2011
Member • Jul 7, 2011
Member • Jul 30, 2011
Member • Jul 31, 2011
My answers are-->ishutopreHere is my first set of doubts.
Topic: metal castings
What is the process used to keep the shape of the casting so that they remain uniform?
1. The casting should be machined rough and kept in open place for months together.
2. The casting should be hammered.
3. The casting should be kept in a furnace.
4. Loam sand should be put on the casting.
How are the internal stresses of a casting removed?
1. By machining off the hard and rigid outer skin.
2. By polishing the casting.
3. By making holes in the moulding box.
4. By making one more gate in the loam sand (pattern sand)
Why are the corners of a casting well rounded off by fillets?
1. The corners are well rounded off because the casting becomes very weak at the corners.
2. To get exact shape.
3. To get extra thickness for the entire job shape.
4. Because the job is having sharp corner shape.
What is the approximate contraction per meter of cast iron while casting?
1. 8 to 9 mm (1/120)
2. 16 to 18mm (1/60)
3. 13 mm (1/77)
4. None of these
second equation is correct. i am sure for second option.ishutopreMy question here today refers to the cutting tools.
Which is equation is commonly used for a lathe machine?
one is V=(257/60[SUP]0.19[/SUP]XS[SUP]0.36[/SUP]Xt[SUP]0.08[/SUP])
Where V is the speed of cutting in mm/min
S is feed in mm/min and t is depth of cut in mm.
And other is VT[SUP]n[/SUP]=C
Where T is tool life and n,C are constants. The rest things are similar
Member • Nov 15, 2011
Member • Dec 20, 2011
can any one tell me the how to find this?Issue
An open rectangular tank accelerates up an inclined plane having inclination of 1 vertical to 4 horizontal as shown below:
For the water surface to move from CE to CB, the acceleration of tank will be
1. 1.98 m/s2
2. 2.9 m/s2
3. 2.3 m/s2
4. None of the above
Member • Dec 21, 2011
i am still a bit confused...IssueCheck out post #10 #-Link-Snipped-# If you face any difficulty, feel free to ask.
