Mechanical Engineer iOS App
@thebigk Oct 24, 2024
"Mechanical Engineer" is the iOS app for professional mechanical engineers and the mechanical engineering students. The app has been developed by Multieducator Inc. and features 300 mechanical engineering formulas, 300 conversion formula and 70 area formulas.
The official description of the app is as follows -
MECHANICAL ENGINEER, part of MultiEducator's iPhone "Formulator" Line, is the perfect tool for any Mechanical Engineer or engineering student. Our Mechnical Engineer app contains over 300 important mechanical engineering formulas, there are over 300 additional conversion formulas in the program as well as 70 area formulas. Major areas covered in the program now include: Actuators Bearings, Belts, Boiler, Brakes, Clutches, Elevators, Gears,Fluid Power, Heat Transfer,Internal Combustion, Kinetic Energy, Metalworking, Plates, Plumbs, Power Plants, Refrigeration,Shafts Springs and Vehicle Drive.
All formulas can be saved. You can access recent or favorite formulas. You can also e-mail the results of any formula. If you do not see a formula you need or like, just e-mail us and we will try to include your request in the next update.
Some of the 300 formulas currently included are:
• Belt Design Horsepower Drive Speed Ratio
• Bearing
• Required Length of Bearing
• Rate of Bearing Heat Generation
• Wall Area
• Bearing Heat Dissipation
• Heat Rise in Bearing
• Brakes
• Torque Required to Stop Load
• Revolutions Prior to Stopping
• Heat Brake Must Dissipate
• Elevator Rope Weight
• Load From Weight
• Rate of Acceleration of Car
• Rope Load Caused By Acceleration
• Bending Load
• Spring Wire Length
• Weight of Spring
• Spring Outside Diameter
• Number of Spring Wire
• Number of Active Springs
• Spring Deflection
• Shear Stress Spring
• Width of the Spring.
• Torsion Bar Springs
• Proportional Limit in Shear
• Diameter of Bar
• Square Bar
• Triangle Bar Size
• Energy Storage Circular
• Energy Storage Square
• Liquid Spring Selection
• Liquid Volume Required
• Cylinder Length
• Spring Rate For Shock Mounted Deflection
• Acceleration of Load
• Isolator Deflection
• Spring Rate
• Spring Rate Per Isolator
Download Link: #-Link-Snipped-#
Cost: $5.99
mechanicalengineer-1mechanicalengineer-2
  • CE Designer
    CE Designer
    @ce-designer-BWq0yl Feb 24, 2012
    This is why i will choose the iphone over any other, the apps available are ridiculously awesome. Thx K, ima get in on my iphone 👍
    @abrakadabra Feb 24, 2012
    CE Designer
    So true. The apps on Android and other OSes are so unworthy.
  • silverscorpion
    silverscorpion
    @silverscorpion-iJKtdQ Feb 24, 2012
    AbraKaDabra
    You are offending an Android fan!!
    Why you no like Android?? 😕
    I'm gonna try and get this app in my Android phone 😒
  • zaveri
    zaveri
    @zaveri-5TD6Sk Apr 7, 2012
    @_k
    is it possible to get this software on pc ? i dont own i-phone and am not planning to do so
  • ISHAN TOPRE
    ISHAN TOPRE
    @ishan-nohePN Apr 15, 2012
    I would rather work with databook. It is easy as far as thorough design problem solving is concerned.
  • engg.ashish
    engg.ashish
    @enggashish-2qk6Q2 May 17, 2012
    just have a look on engineering power tools plus 😉 for windows its good enough
  • CE Designer
    CE Designer
    @ce-designer-BWq0yl May 18, 2012
    engg.ashish
    Will try this software
