MECER UPS HELP
KIND REGARDS,
AGUTU L
Member • Sep 26, 2012
It is difficult to let you know without checking the hardware but you can open hardware and check if there is any blown part or any damaged chips. You need to replace that part if any.agutulawyHI, GUYS I REQUEST A HELP ON THE MECER UPS ITS SHOWING OVERLOAD WHILE NO LOAD IS CONNECTED ,AGAIN IT THE UPPER RED L.E.D IS ON AND I SUSPECT TO BE INTERNAL FAULT PLEASE ADVICE WHICH PARTS ARE FAULTY
KIND REGARDS,AGUTU L
Hi,godfatherIt is difficult to let you know without checking the hardware but you can open hardware and check if there is any blown part or any damaged chips. You need to replace that part if any.
Then it is difficult to recognize problem.agutulawyHi,
Hi,
No part is blown im just suspecting the control board please advice
Member • Sep 27, 2012
