Maxi Compact System 1.0 - 14.0kW 48V DC
charlybrown
@charlybrown-OzO7XS • Oct 18, 2024
Hi can anyone please help me and explain me what is the function of the swichts in circles please.
here are some details.
I just want to know the function of each one in a easy language, something like what each or group of switch is for.
thanks.
[FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]AC Input:[/SIZE][/FONT]​ [FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]Three phase
(refer to RM18XX, RM20XX series brochures for full details)
[/SIZE][/FONT]​ [FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]Frequency Range:[/SIZE][/FONT]​ [FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]45-66Hz[/SIZE][/FONT] [FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]Power Factor: [/SIZE][/FONT]​ [FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]>0.99 (full load)[/SIZE][/FONT] [FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]Efficiency:[/SIZE][/FONT]​ [FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]>91% (>50% power output)[/SIZE][/FONT] [FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]Termination:[/SIZE][/FONT]​ [FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]Three phase L1, L2, L3, N, E 10mm² terminal blocks
Surge protection (40kA 8/20msec)
[/SIZE][/FONT]
[FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]DC Output[/SIZE][/FONT]​
[FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]Nominal Voltage:[/SIZE][/FONT]​ [FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]-48V, -60V (+24V available to special order)[/SIZE][/FONT] [FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]Rated System
Output Power:
[/SIZE][/FONT]​ [FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]14000W
@ -48V
[/SIZE][/FONT] [FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]Polarity:[/SIZE][/FONT]​ [FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]Positive earth (negative earth available to special order)[/SIZE][/FONT] [FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]DC Distribution:[/SIZE][/FONT]​ [FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]Load: 2x 10A, 6x 32A, 2x 50A load circuit breakers
Battery: 4x 100A battery circuit breakers
[/SIZE][/FONT] [FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]Breaker Fail Detection:[/SIZE][/FONT]​ [FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]Electronic fail detection on both load and battery breakers[/SIZE][/FONT] [FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]DC Terminals:
(rear connected)
[/SIZE][/FONT]​ [FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]Load: 10A, 32A, 10mm² tunnel terminals
50A, 16mm² tunnel terminals
Battery: 35mm² tunnel terminals
[/SIZE][/FONT] [FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]Low Voltage Disconnect:[/SIZE][/FONT] [FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]400A battery LVD fitted as standard[/SIZE][/FONT]
[FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]Mechanical[/SIZE][/FONT]​
[FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]Size:[/SIZE][/FONT]​ [FONT=Helvetica, Geneva, Arial, SunSans-Regular, sans-serif][SIZE=-2]Width: 482.6mm (standard 19” module)
Height: 222.2mm (5U, 8¾”)
Depth: 350mm (13¾”) (390mm with cable strain relief)
[/SIZE][/FONT]
    @thebigk • May 20, 2009
    Thread moved to electrical/electronics engineering section.
