MATLAB: Ultimate Tool
MATLAB is a high-level technical computing language and interactive environment for algorithm development, data visualization, data analysis, and numeric computation. Using MATLAB, you can solve technical computing problems faster than with traditional programming languages, such as C, C++, and Fortran!!
You can use MATLAB in a wide range of applications, including signal and image processing, communications, control design, test and measurement, financial modeling and analysis, and computational biology.
MATLAB provides a number of features for documenting and sharing your work. You can integrate your MATLAB code with other languages and applications, and distribute your MATLAB algorithms and applications.
Check out the demos at #-Link-Snipped-#
![[โIMG]](proxy.php?image=http%3A%2F%2Fwww.mathworks.com%2Fcmsimages%2Fml_helicopterapp_wl_7167.gif&hash=c6a19a743e52b427da68e168a8c2d0be)
How many of you have used this software? If not, just give it a try. I did my Electromechanical Lab report calculations and graphs with this progie!
Can use it even for Finantial Visualisation, Network simulation and other fields.
