MATLAB : Find load flow in radial distribution network
maraitamilan
@maraitamilan-YIpgyG โ€ข Oct 27, 2024
Hi friends doing my M.E project on reconfiguration of radial distribution network for that first step is to find load flow in radial distribution network can any body help me to do with the matlab coding for this please help
  • arunchary
    @arunchary-VtqB3c • Sep 10, 2013
    can you please share the related paper such that we can provide a solution............
  • maraitamilan
    @maraitamilan-YIpgyG • Sep 11, 2013
    for radial distribution 33 bus boss using forward/backward sweep
  • arunchary
    @arunchary-VtqB3c • Sep 12, 2013
    ok.
    please follow the paper where he discussed in steps to implement the code....
  • arunchary
  • maraitamilan
    @maraitamilan-YIpgyG • Sep 15, 2013
    load flow now ok have to start with branch and bound technique
  • shruti21
    @shruti21-sH4K4s • Sep 16, 2013
    hello boss. doing my project on the topic reconfiguration of distribution network for loss minimization and facing the same problem of radial load flow. i have gone through a few of radial load flow papers based on forward backward sweep. coding part is problematic. i really need help! please help
  • maraitamilan
    @maraitamilan-YIpgyG • Sep 16, 2013
    hi Shruti21 using which technique going to reconfigure.... and btw i got load flow for radial system
  • shruti21
    using GA. u got the load flow code ?
  • maraitamilan
    u are using only one objective or multiobjective????..... ya got the code
  • arunchary
    @arunchary-VtqB3c • Sep 16, 2013
    hi guys please share the following code where u getting issue ok such that ill go through once and ill try to solve ok...........
  • shruti21
    hi sir..share ur email id ,so that i can mail u the code
    @abhishek-fg9tRh • Sep 16, 2013
    @#-Link-Snipped-# Why not share your Matlab code here itself ?
    Many CEans will indirectly get help from your code too.
  • arunchary
    shruti21hi sir..share ur email id ,so that i can mail u the code
  • yahya idrias
    @yahya-idrias-dhTA6n • Oct 7, 2013
    hello sir i have a same problem, my project is reconfiguration network fo real loss reduction to increase the reliability network, may anyone may help me with the matlab code, it's starting to depressed me...
  • Chaitali Sumita
    @chaitali-sumita-Bn5O8f • Feb 10, 2014
    Hi friends....
    I've solved different papers for load flow in radial distribution system and one paper for mesh network.
    So I can help you for load flow..
    But i need some help in reconfiguration. How can i approach for reconfiguration????
    Waiting for your replies.
  • Chaitali Sumita
    Hi...
    U can ask me for load flow.... i got the results...
    I'm also working for reconfiguration..
  • maraitamilan
    @maraitamilan-YIpgyG • Feb 10, 2014
    use any of the evolutionary algorithm for reconfiguration
  • Chaitali Sumita
    maraitamilanuse any of the evolutionary algorithm for reconfiguration
    evolutionary algorithm means????
    Can u tell me some clearly....
  • maraitamilan
    genetic,differential, harmony search etc
  • Chaitali Sumita
    I'm trying to solve "A NEW ALGORITHM FOR THE RECONFIGURATION OF DISTRIBUTION FOR LOSS MINIMIZATION"
    IEEE Transactions on Power Delivery. Vol. 7, No. 3, July 1992.
    CAN U HELP ME FOR THIS????
  • Chaitali Sumita
    maraitamilangenetic,differential, harmony search etc
  • maraitamilan
    1992.... might be old strategy new ideas might arrived at this time
  • Chaitali Sumita
    maraitamilan1992.... might be old strategy new ideas might arrived at this time
    can u suggest me any paper which is easy to understand the concept of reconfiguration?????
  • Chaitali Sumita
    @chaitali-sumita-Bn5O8f • Mar 3, 2014
    sooraj narayanHai sooraj narayan...
    I think u r making program for the paper titled as "a direct approach for distribution system load flow solution" by J H Teng. U can mail me your program to my mail #-Link-Snipped-#
    I've solved that paper. but i don't want to give my program.
    however i can help to identify the mistakes in ur program or i can provide u results for any system to do ur thesis work.
    If u want results only, u can mail me the data for any bus system.
    The email id which i've mentioned is not my personal id. I'll check that mail weakly once. so please be patience to get the reply from me.
  • Chaitali Sumita
    Hai maraitamilan..
    Thanks for your suggestion about reconfiguration. I've searched for latest papers and i got the program for reconfiguration. I would like to thank you for your replies to my questions. Thank u once again....
  • Chaitali Sumita
    sooraj narayanANOTEHR CODE:
    clear all
    clc
    i=sqrt(-1);
    % eval('linedata15bus')
    % eval('loadadata15bus')
    eval('line33')
    eval('load33')
    nbus=max(max(line๐Ÿ˜€,3)),max(line๐Ÿ˜€,2)));
    nbranch=length(line๐Ÿ˜€,1));
    fb=line๐Ÿ˜€,2);
    tb=line๐Ÿ˜€,3);
    R=line๐Ÿ˜€,4);
    X=line๐Ÿ˜€,5);
    MVAb=100e6;
    KVb=12.66e3;
    Zb=(KVb^2)/MVAb;
    Z=R+(i*X);
    Zpu=Z/Zb;
    PL=busd๐Ÿ˜€,2)/MVAb
    QL=busd๐Ÿ˜€,3)/MVAb
    delV=zeros(1,nbus);
    iter=1;
    ILL=[];
    V=ones(nbus,1);
    Vprev=V;
    IL=[];
    dVmax=1;
    % while (dVmax>0.00001)
    while(iter<200)
    for k=1:nbus
    IL(k,1)=conj((PL(k)+(i*QL(k)))/V(k));
    end
    ILL=IL;
    for k=nbranch:-1:1
    p=fb(k);
    q=tb(k);
    ILL(p)=ILL(p)+ILL(q);
    end
    Ibr=ILL(tb);
    for k=1:nbranch
    delV(k,1)=(Zpu(k)*Ibr(k));
    end
    for k=1๐Ÿ˜”nbus-1)
    V(tb(k),1)=V(fb(k),1)-delV(k,1);
    end
    dV=V-Vprev;
    dVmax=max((dV));
    Vprev=V;
    iter=iter+1;
    end
    iter
    disp('BUS VOLTAGES ARE');
    abs(Vprev)
    disp('BRANCH CURRENTS ARE');
    abs(Ibr)
    I think u r making program for the paper titled as "a direct approach for distribution system load flow solution" by J H Teng. U can mail me your program to my mail.
  • Jigar123
    @jigar123-nSmQVM • Mar 18, 2014
    hi shruti21, I am trying to implement code for ladder network theory. It will be helpful to me if you will help me with the code of forward backward seep method.
  • Vanipd
    @vanipd-WkRI3a • Apr 16, 2014
    Sir,
    I would like to do my project on the topic โ€˜Power Loss Minimization in Distribution System Using Network Reconfiguration in the Presence of Distributed Generationโ€™- (IEEE TRANSACTIONS ON POWER SYSTEMS, VOL. 28, NO. 1, FEBRUARY 2013) But I donโ€™t know how to start.๐Ÿ˜”... May anyone please give me guidelines for starting my project..
  • Vanipd
    @vanipd-WkRI3a • Apr 20, 2014
    y no replies?? ๐Ÿ˜”
  • Raviteja16
    @raviteja16-rQOZtU • Apr 25, 2014
    VanipdSir,
    First u've to do load flow analysis for radial distribution system.
    after this u can get the idea how to integrate Distributed generation into radial distribution system and how to do reconfiguration.
    so choose a good paper and start writing program for load flow of radial dist. system.
  • Vanipd
    @vanipd-WkRI3a • Apr 26, 2014
    Raviteja16First u've to do load flow analysis for radial distribution system.
    Sir, thank you for ur reply
    Any suggestion for such papers??
  • Raviteja16
    @raviteja16-rQOZtU • Apr 27, 2014
    VanipdSir, thank you for ur reply
    First try to search for papers in Google. If you couldn't get any paper, then i'll suggest some papers for load flow.
  • Vanipd
    @vanipd-WkRI3a • Apr 30, 2014
    y we r nt choosing Conventional METHODS such as Gauss Siedel , NR..... ??
  • yahya idrias
    @yahya-idrias-dhTA6n • May 5, 2014
    hello, does anybody have finish this work?
    i really need help for this one
  • Raviteja16
    @raviteja16-rQOZtU • May 9, 2014
    Vanipdy we r nt choosing Conventional METHODS such as Gauss Siedel , NR..... ??
    1. NR & GS methods require solutions of set of equations whose size is of the order of number of the buses. This results in long computation time.
    2. For distribution system, Ybus matrix is very sparse => waste of memory storage.
  • Raviteja16
    yahya idriashello, does anybody have finish this work?
    Which type of help you need??? Load flow???
  • yahya idrias
    @yahya-idrias-dhTA6n • May 9, 2014
    Raviteja16Which type of help you need??? Load flow???
    yes sir, i have a load flow program using newton raphson.
    but i still confuse how to get the feeder with minimum loss.
    really need a help sir.
    thanks for replying my post ๐Ÿ˜€
  • Vanipd
    @vanipd-WkRI3a • May 9, 2014
    yahya idriasyes sir, i have a load flow program using newton raphson.
    #-Link-Snipped-# .... for me too........ ๐Ÿ˜”
  • Raviteja16
    @raviteja16-rQOZtU • May 11, 2014
    for which
    for which type of system you would like to do load flow???
    Transmission or distribution??
    U can use modified NR for distribution system also.
    Presently i'm working on Distribution Side.
    If u r working on Transmission side, u can take some others help...
  • Vanipd
    @vanipd-WkRI3a • May 12, 2014
    Raviteja16for which
    Sir am using IEEE 69 bus radial distribution system
  • yahya idrias
    @yahya-idrias-dhTA6n • May 12, 2014
    Raviteja16for which
    i am working on distribution side in my country sir...
    using ieee 33 and 69 bus the first step.
    my present work is make a radial to mesh system and than count load flow by opening switch one by one...
    that why i confuse how to count using matlab when one switch is open.
    i just know a little about matlab.. really need a help sir..
  • Vanipd
    #-Link-Snipped-# which paper u r following??
    am also doing in IEEE 69 bus radial distribution s/m.....
    if u can plz give me ur contact id.... for constant replies....
  • yahya idrias
    @yahya-idrias-dhTA6n • May 13, 2014
    Vanipd#-Link-Snipped-# which paper u r following??
    you can email me here mam : #-Link-Snipped-#
    hope that we can help each other.. ๐Ÿ˜€
  • shipra jhariya
    @shipra-jhariya-L7J8dK • May 19, 2014
    hello..mi thesis topic is also d same as above.. " network reconfiguration of radial distribution system using GENETIC ALGORITHIM in MATLAB". Firstly I have to calculate power loss using load flow using forward backward sweep algorithm. pls help me
  • Raviteja16
    @raviteja16-rQOZtU • May 19, 2014
    VanipdSir am using IEEE 69 bus radial distribution system
    Ok...
    did you take any base paper for load flow????
    If not, U can take any one among these papers listed below.
    1. "A Direct Approach for Distribution System Load Flow Solutions" by J H Teng, IEEE Transactions on Power Delivery, 2003, 18(3):882-887 (Page numbers).
    2. "Topology based approach for Efficient Load flow Solution of Radial Distribution Networks" by KVS Ramachandra Murty, et al; 16th National Power System Conference, 2010, 176-179
    3. "Simple and efficient method for load flow solution of radial distribution networks" by D. Das , et al; Electrical power & Energy Systems, 1995, 17(5): 335-346.
    4. "A Novel Load Flow Method for Radial Distribution Systems for Realistic Loads" by K Nagaraju, et al; Electric Power Components and Systems, 2001, 39(2): 128-141.
    I've idea on these papers for load flow solution of radial and mesh distribution systems.
    I can help u for these papers.
  • Raviteja16
    @raviteja16-rQOZtU • May 20, 2014
    yahya idriasi am working on distribution side in my country sir...
    counting load flow???
    do you mean number of iterations???
    if so, try to implement the load flow for radial as well as mesh networks for 33 bus system. Later u can remove the loops one by one in mesh load flow program to count number of iterations...
    for IEEE 33 bus system, You'll get less number of iterations for mesh network (with 5 loops) than radial network.
  • shipra jhariya
    @shipra-jhariya-L7J8dK • May 20, 2014
    thanku for d repli..
    except serial no. 2 I have read other papers and for fbsa mi base is "a simplified approach for load flow analysis of radial network" , K.Vinoth kumar ,M.P.Selvan
    I am trying to follow the flowchart but...
  • Raviteja16
    shipra jhariyahello..mi thesis topic is also d same as above.. " network reconfiguration of radial distribution system using GENETIC ALGORITHIM in MATLAB". Firstly I have to calculate power loss using load flow using forward backward sweep algorithm. pls help me
    first search for papers in internet and select one good paper for load flow.
    Try to understand the concept in that paper and then go for programming.
    If you get any doubts in concept or programming, post in crazyengineers..
    We are here to help you..
  • Raviteja16
    shipra jhariyathanku for d repli..
    Just now i read your paper...
    Its a good one..
    and authors presented their idea in very easy manner.
    They have given each and every step for programming also...
    Then where u r getting the problem?????
  • shipra jhariya
    yes ofcourse...I have the theory knowledge about Forward backward algorithm and also started matlab coding where I found only current injection at any node say (n) assuming flat voltage Vn=1+j*0. But in line charging current, how voltage has to be take Vb..?
