Master slave
harshitha
@harshitha-x5uLUN โ€ข Oct 23, 2024
๐Ÿ˜•please tell me how to make one hard disk the master and the other one slave when there are two hard disks in the same computer system?
wat is no pin pair?
  • friendster7
    @friendster7-oVJr9h • Jul 17, 2008
    if you r having 2 hard disk read the instruction given on the top of the hard disk because the jumpher setting for different hard disk may be different.so make one hard disk master with slave by putting the jumpher(connector of two pins)in appropriate no pin pair and make another slave connect the two hard disks with the IDE cable(do it after turning off your computer).after then start your computer for clarification check your BIOS setting whether whatever you have don is right or not.in BIOS main section the information about master and slave is given
  • vijayrock
    @vijayrock-oRDtL8 • Jul 19, 2008
    The previous post provides the correct answer
    Check the vendor's manual as how to change the jumper.
    For making the Hard disk master and slave the change of jumper position is a must.
  • Itanium
    @itanium-haHgZn • Aug 1, 2008
    Vinay is right.
