  • mass flow sensor
    mechky
    mechky
    @mechky-jbqpJD
    Updated: Nov 14, 2024
    Views: 1.3K
    A mass air flow sensor is used to measure the mass flow rate of air, and gives output in the form of a 0-5V signal or a PWM signal that is proportional to the air mass flow rate.
    How will I determine from the output voltage that what amount of air is flowing?
    You cannot
    mechky
    . Most mass flow meters inject some heat upstream and measure the difference in temperature. Since Q=mC(Del.T) and Q C and Del.T are known m can be calculated. Most meters are calibrated for a particular gas. Del.T is related to the output voltage.
    <a href="https://www.flowmeters.com/" target="_blank" rel="nofollow noopener noreferrer">Flow Meters | Find and Buy Flowmeter Equipment | Universal Flow Monitors</a>
  • thalaraju
    MemberFeb 17, 2012
    latest eee projects give me any idea
  • Huang Ella
    MemberNov 14, 2024
    Hello, we are Flow meter, water meter, air meter, gas detector manufacturer. https://www.lnalsafe.com/, WhatsApp: +8613437856962
