Manufacturer uses 8 cylinder for 3200cc engine. why they are not using single big cylinder Having 3200 cc engine capacity?
    @ramani-VR4O43 Sep 29, 2018
    Sure you can. If you want your car to behave like a giant kangaroo.
    Eight cylinders working at different angles of the fullcycle as designed by the crank shaft is more efficient and gives a smoother ride.
  • Bala Venkat
    @bala-9uENbq Nov 24, 2018
    Interesting question mate #-Link-Snipped-# I think it's because of the geometry of the design. The bigger the piston, the lesser the power per weight. If we use a single cylinder, to derive the same amount of power, you would need somewhere around 6 or 7 liters instead of much lesser. ?  scratching my head.
  • jignesh bhatt
    @jignesh-a0csLJ Nov 24, 2018
    multicylinder engine kicks power more time during singpe revolution of crank, gives turbine like smoothness and also allowed to lightweight flywheel hance kerb weightnof vehicle....bla ..bla...bla
