Making A Hyperterminal Calculator By Interfacing With Hcs12e128
suga_babe
@suga-babe-tCEFOr Oct 25, 2024
i have a project to design a calculator with the hyperterminal by writing a source code and compile it with the CodeWarrior. i am using the motorolla S12E128.
i have wrote a code for the interfacing between the two, but i am stuck when coming to the calculator's part. here is the code i wrote so far - which was tested-
i need help in writing the rest... thanks
#include <hidef.h> /* common defines and macros */
#include <mc9s12e128.h> /* derivative information */
#pragma LINK_INFO DERIVATIVE "SampleS12"
void periphlnit(void){
SCI1BDH=0x00;
SCI1BDL=0x34; //sets SCI baud rate to 9600,N,8,1
SCI1CR2=0x08;
void Write(const char*text){
while(*text !='\0'){
while(!(SCI1SR1 & 0x80))
SCI1DRL=*text++;
void delay(int);
void delay(int n){
while(n>0)n--;
void main(void){
periphlnit();
EnableInterrupts;
for(;{
Write ("Tested on Micro lab\n\r");
delay(32000);
    @harshad-ukH5ww Dec 11, 2011
    So basically you have problem while you sending some texts to pc right? Can you please let me know your SCI settings?
    @harshad-ukH5ww Dec 14, 2011
    suga_babei have a project to design a calculator with the hyperterminal by writing a source code and compile it with the CodeWarrior. i am using the motorolla S12E128.
    SCI1BDH=0x00;
    SCI1CR2=0x08;
    SCI1DRL=*text++;
    void delay(int);
    void delay(int n){
    while(n>0)n--;
    void main(void){
    periphlnit();
    EnableInterrupts;
    for(;{
    delay(32000);
    I think there may be problem with initialization remaining code looks OK.
    Thread moved to Electrical and Electronics Section.
  • suga_babe
    @suga-babe-tCEFOr Dec 15, 2011
    my main issue is how to desogn the calculator itself.. how to assign the values and commands in the source code so the calculations can be performed.. got me ? :/
    @harshad-ukH5ww Dec 15, 2011
    suga_babemy main issue is how to desogn the calculator itself.. how to assign the values and commands in the source code so the calculations can be performed.. got me ? :/
    Are you going to design GUI at PC side? microcontroller or PC who performs the calculation?
  • suga_babe
    @suga-babe-tCEFOr Dec 22, 2011
    i thought about using the switch statment for start.. to compare between two numbers and give the smallest or the largest
    @harshad-ukH5ww Dec 22, 2011
    Still i'm not clear with your query. You're sending numbers from hyperterminal and processing it in microcontroller?
  • suga_babe
    @suga-babe-tCEFOr Dec 25, 2011
    no ..am writing a function in the C program, send it to the microcontroller and show the output in the hyperterminal
