make machine it can dissolve crystals in minimum time
shinde_tukaram
@shinde-tukaram-r8Oc6l โ€ข Oct 26, 2024
we want an machine which dissovle one inch of crystal in one liter in lase than 5 min, we have 12 volt of supply and only electrical applications are use and machine dimensions should be 30*30 ๐Ÿ˜๐Ÿ˜•
  • Vega
    @vega-Ic42ds • Jan 14, 2010
    1) Well, mechanical currents in solvent can speed up the dissolution process. So you can stir your solvent by some method.
    2) If you can crush the crystal, it will help speed up dissolution process. Crushing will expose more surface area to solvent, but I am not sure if this fits into your conditions.
    3) How about some electrolysis (or whatever it is called) ? I am not sure abt it.
  • shinde_tukaram
    @shinde-tukaram-r8Oc6l • Jan 21, 2010
    how i can dissolve cuso4 crystals in minimum time
    how i can dissolve cuso4 crystals in minimum time.
    ๐Ÿ˜•
    ๐Ÿ˜•
