[Machine Design] - Theories of failure under static load
ShrinkDWorld
@shrinkdworld-WWdBBc Oct 22, 2024
  • Need of these theories
The strength of machine member depends on material used. And these properties are usually calculated from simple tension or compression tests. There for predicting the failure stresses for member subjected to bi-axial or tri- axial stress is more complicated.
The principal theories of failure for machine member subjected to bi-axial stress are as follows.
1] Maximum Principal (or normal) Stress theory (Also known as Rankine Theory)
2] Maximum Shear Stress theory (also known as Guest’s or Tresca’s theory )
3] Maximum principal (or normal) Strain theory (Also known as Saint Venant Theory)
4] Maximum Strain energy theory (also known as Haigh’s theory)
5] Maximum distortion energy theory (also known as Hencky & Von Mises theory)
For brittle materials, the limiting strength is the ultimate stress tension or compression
For ductile materials, the limiting stress is the stress at yield point.
  • ShrinkDWorld
    @shrinkdworld-WWdBBc Jul 23, 2011
    1] Maximum Principal or normal Stress theory ( Rankine Theory) -->
    According to this theory, the members fails when maximum principal or normal stress in system reaches to limiting value.
    Limiting stresses
    For ductile material is yield stress
    For brittle material (do not have well definite yield point) is ultimate stress.
    According to above theory, taking factor of safety (F.S.) in account , the principal or normal stress (δt1 ) in a bi-axial stress system is given by
    δt1= δyt/F.S. For ductile materials
    δt1= δut/ F.S. For brittle materials
    Where,
    δyt =Yield stress in tensile test
    δut = Ultimate stress
    This theory is generally used for brittle materials.[FONT=&quot]
    [/FONT][FONT=&quot]
    [/FONT]
  • ShrinkDWorld
    2] Maximum Shear Stress theory (Guest’s or Tresca’s theory ) -->
    According to this theory, the failure is occurs at a point in member when maximum shear stress reaches to the value equal to shear stress at yield point in simple tension test.
    Mathematically
    τmax = τyt/F.S.
    where,
    τmax = Maximum shear stress in system
    F.S.= factor of sefty
    τyt = Shear stress at yield point determined from simple tension test.
  • ShrinkDWorld
    3] Maximum principal (or normal) Strain theory (Also known as Saint Venant's Theory)
    According to this theory the failure/ yielding occurs at a point when maximum principal strain reaches to limiting value of strain.
    where
    δ[SUB]t1[/SUB]& δ[SUB]t2[/SUB] = Maximum & minimum principal stresses.
    ε= strain at yield point.
    1/m = Passions ratio
    E= Young’s Modulus.
    F.S.= Factor of safety
    This theory is rarely used due to unreliable results in many cases.
  • ShrinkDWorld
    {Reserved For 4] Maximum Strain energy theory (also known as Haigh’s theory)}
  • ShrinkDWorld
    {Reserved For 5] Maximum distortion energy theory (also known as Hencky & Von Mises theory)}
    Now below we can discuss above topic.
  • scot davidson
    @scot-davidson-TiiYvi Jan 9, 2016
    Am really sorry to disturb you but would you mind having a look at this question for me as I don't know what approach to take with this question thank you
  • Jah Knows
    @jah-eckCwF Nov 17, 2018
    How to find factor of safety using  (MSST) without given yield stress
