@xheavenlyx-CbvN62 • Oct 9, 2006
Ill take a shot:
Logical addrs: Its the address which we can see work on in calculations or programs at runtime. Eg, a pointer pointing to memorie.
Physical addrs: Its the actual addrss of the byte in hardware (ed, ram/rom) which is mapped by the logical addrss. After every compilation/execution the logical add can change but the physical will never.
Is it right is it right is it right? -
Mahesh OP
@mahesh-wLPhv2 • Oct 9, 2006
Xh,you are correct but I want to know about how logical address is calculated and to what value it is added to get physical address.
MaheshXh,you are correct but I want to know about how logical address is calculated and to what value it is added to get physical address.
You append a zero at the end of a logical addrs to get the physical addrs. Thats what is dont in a pentium type processor. Dont know about the AMD or others.
Mahesh OP
I don't think that by keeping 0 at last in logical address we get physical address.It varies from one process to other.Its value is added to base rregister address to get physical address.
No, this one I dont know๐
Give the answer in detail if you do. I really want to know.
Regards -
Mahesh OP
I think you have this addressing in M.P. There we have this type addressing in 8086 .But this differs with addressing in our Computer Organisation.In this,
CPU generates logical address and physical address is found by adding with this with the value in a special register called relocation register. -
@aashima-eO93l9 • Oct 10, 2006
Well physical address what i can recall is a part of the effective address. It is the actual path of the location of the particular data in the memory or elsewhere. Is it right?
Mahesh OP
@mahesh-wLPhv2 • Oct 11, 2006
Yes, you are correct.But I'm want to know more about logical address.
@sandhya23-KeZJPu • Nov 11, 2008
The address generated by CPU is referred to as a logical address.
The address seen by the memory unit ,i.e,the one loaded into the memory address refister of the memory is referred to as physical address -
@sauravgoswami-UAfTlI • Nov 12, 2008
After following ur discussion i came to know logical adder is adder generated by assembly language were as physical adder are those performed with digital gates and components...
@manupep-fYm2v7 • Nov 17, 2008
Logical address and physical address comesin many situations (not only memory ,paging ..etc)
As a general talk we can say that physical address is the actual address of device, memory unit or whatever it is
Logical address is the address used by us for the better understandability of ourselves . Actual physical address format is difficult to handle (because of complex format) in our communicatin purposes . So we use logical address and mapping this logical add to physcical address.
If the doubt is still persist i will give one eg:
Everyone is aware of IP address . It is the address used to identify one machine in a network. (actually it is the address of the network card in that machine). But the actual address of the card ( the burned address by the manufacture is MAC address it is 48 bit long) .But we use IP address instead of MAC for comm. This situation IP is the logical address.
The meaning of logical , and physcical addr is situation dependent -
@ravitejag-02nJVr • Nov 17, 2008
excellent manu :clap:
i got a clear idea about them now๐
