Load distribution between slab and beams & in what proportion?
hareesh ce
@hareesh-ce-18IlBe โ€ข Oct 26, 2024
hey guys, plz let me get out of the confusion,
how the load is distributed from slabs to beam and in what proportions???????
for the right block of the building in the plan
  • hareesh ce
    @hareesh-ce-18IlBe • Mar 20, 2012
    hareesh cehey guys, plz let me get out of the confusion,
    plz plz gve me solution as soon as possible
  • Infinity
    @infinity-RRVcWi • Mar 21, 2012
    Didn't get your question. Please clear these things:
    1. what does CR means.
    2. By Load distribution you want to know what load each part of beam will bear?
  • hareesh ce
    @hareesh-ce-18IlBe • Mar 21, 2012
    InfinityDidn't get your question. Please clear these things:
    CR is Class Room, its a school building.
    yeah i want to know how the load is distributed for extrnl and internal beams
  • Infinity
    Thanks for the clarification. As far as i can see, all these slabs are spanning in one direction only. And IS 456: 2000 specifies load distribution only for slabs spanning in 2 directions at right angle. I think you can apply that in this case as well (not a big issue). It will depend on the side lengths but as per the figure I think all 4 sides of class room are almost equal. so load distribution will be same else if sides are unequal follow fig7 in IS code at page 41. you will have to draw lines at 45 degree and accordingly distribute the load. I hope this helps.
  • hareesh ce
    @hareesh-ce-18IlBe • Mar 22, 2012
    InfinityThanks for the clarification. As far as i can see, all these slabs are spanning in one direction only. And IS 456: 2000 specifies load distribution only for slabs spanning in 2 directions at right angle. I think you can apply that in this case as well (not a big issue). It will depend on the side lengths but as per the figure I think all 4 sides of class room are almost equal. so load distribution will be same else if sides are unequal follow fig7 in IS code at page 41. you will have to draw lines at 45 degree and accordingly distribute the load. I hope this helps.
    thanku very much boss
    had a gr8 & valuable information.... thnku so much ๐Ÿ˜€
  • Infinity
    @infinity-RRVcWi • Mar 22, 2012
    hareesh cethanku very much boss
    You are welcome ๐Ÿ˜€ BTW I have just given an approach to proceed but if you are constructing this building then proper structural design is must for which you can use some software like STAAD.Pro/SAP/ETABS etc.
  • Souravd
    @souravd-VqH39l • Mar 30, 2012
    InfinityYou are welcome ๐Ÿ˜€ BTW I have just given an approach to proceed but if you are constructing this building then proper structural design is must for which you can use some software like STAAD.Pro/SAP/ETABS etc.
    I completely agree with you. Design will be much more viable if you use the design software.
  • rekcah
    @rekcah-TiEtTy • Nov 2, 2012
    just download ACI-318 in CHAPTER 13โ€”TWO-WAY SLAB SYSTEMS, it explain how the loads distributed from the slabs to the beam
  • ajay kudekar
    @ajay-kudekar-C7eK3l • Aug 30, 2015
    what is coupler in TOS? hou to clearify?
    pleaseeeeee clear it.........
