  • Sumukh Madgaonkar
    @sumukh-T0cfqu • Oct 21, 2016
    PRAD CHAKRABORTYWould you mind if I want to know the compression and tensile load carrying capacity of ISA 25 X 25 X 3 MM,having 01 metre of length.
    Roughly 10kN compressive & 30kn tensile for standard Fe250 grade.
    May change depending on the end conditions and connection.
  • PRADIP CHAKRABORTY
    @pradip-MzE4HZ • Oct 23, 2016
    Sumukhm39Roughly 10kN compressive & 30kn tensile for standard Fe250 grade.
    thanks a lot for this valuable information
  • Mohan Chidambaram
    @mohan-1Zp8VR • Dec 21, 2018
    i want table showing load bearing capacity of MS, Steel, Aluminium for use in solar panel mounting structure.  cmohana@yahoo.com
    @ramani-VR4O43 • Dec 21, 2018
    That is an open question. Too many variables. Basic strength of materials are freely available in various handbooks and engineering sites on the net.
    Unless the solar panel structure (including weight) is known along with expected wind loads, it would be difficult to design the support structure. Another factor that should be kept in mind is the expansion and contraction of the whole set up caused by the heating and cooling of the whole system because of diurnal variations of temperatures between day and night.
