  • Live demonstration of packets
    Manish Goyal
    Manish Goyal
    @manish-r2Hoep
    Updated: Oct 25, 2024
    Views: 1.1K
    Guys i hope you must be aware of a subject named "computer network" that you will or had learned during your course,here you must had learned about various packets such as ICMP,ARP,TCP,IP etc
    But Have you ever see actual working of these packets , how these packets flow ?what if you see live in your pc the content of these packets?
    I hope most of you will guys answer yes
    Not a problem through ce labs,you will not only get deeper knowledge of these packets but also get a practical knowledge
    All this need some time of yours and a little bit knowledge of programming in java.
    So i will begin with TCP Packet
    once you get an idea of basics about this then we will proceed with live demonstration of this packet
  • Voltaire
    MemberAug 2, 2010
    Go ahead. Sounds interesting
  • sushant005
    MemberAug 2, 2010
    This semester i am having "Computer Network" so this might be very interesting to see the live flow of packets.Good work goyal..before showing the live demonstration please give some ideas about the various packets......
  • mayjune
    MemberAug 3, 2010
    You can do this also with a simulator like packet tracer. But it'll be good, to see it through code. thanks a lot. waiting for it...
  • Manish Goyal
    MemberAug 3, 2010
    Here is My first post
    Note:-If anyone doesn't agree with me at any point he/she can correct me and Please no more thanks and praise in this thread as this can distract anyone
    so Let us begin with one of the basic definiton of computer network
    A computer network is just a interconnection of autonomous computers/devices or in simple definition a collection of devices connected by communication channels
    It is used to facilitate communication and transfer of data from one location to another
    For any kind of communication through computer network
    WE require five elements
    1:-Sender
    2:-Receiver
    3:-medium
    4:- Protocol
    5:-Message or data
    Here our main concern is our precious data and protocol.
    Now the data is transmitted in the form of packets,these packets may also be referred to as cell,segment,block
    It has primarily two parts
    1:-Header-It contains all the necessary information required to transfer data such as port no,address etc
    2:- Data:-Next part is our data that we want to communicate
    Now these packets can be of any type may be TCPPacket,IPPacket ,ICMP,ARP etc
    So these are some basics of computer network,tomorrow we will start with TCPPackets
    PS:-If i have missed anything then feel free to add and correct me
  • Manish Goyal
    MemberAug 4, 2010
    For demonstration of packets ,
    Please install following
    1:-Jpcap ,I would recommend to use window platform for this
    2:- winpcap from here
    <a href="https://www.winpcap.org/" target="_blank" rel="nofollow noopener noreferrer">WinPcap - Home</a>
    WinPcap is the industry-standard tool for link-layer network access in Windows environments: it allows applications to capture and transmit network packets bypassing the protocol stack, and has additional useful features, including kernel-level packet filtering, a network statistics engine and support for remote packet capture.
    3:-Java run time environment
  • mayjune
    MemberAug 4, 2010
    Done Boss 😀
  • Manish Goyal
    MemberAug 4, 2010
    cool
    Just for testing whether everything is working fine or not
    Try to execute this program ,it will display information related to network interface card available in your pc
    import jpcap.*;
    class Network
    int i;
    try
            NetworkInterface[] devices = JpcapCaptor.getDeviceList();
            //for each network interface
            for (i = 0; i < devices.length; i++)
                      System.out.println(i+": "+devices[i].name + "(" + devices[i].description+")"+devices[i].loopback);
    catch(Exception e)
        System.out.println(e.getMessage());
    Note :-It is important to know from you Guys whether you want theory first or practical or simultaneously both
    Everything should be in such a way that everyone would learn what we are learning here?
  • sushant005
    MemberAug 4, 2010
    I think simultaneously both theory and practical....it keeps update with theory and its practical as well....
  • mayjune
    MemberAug 4, 2010
    Yup. First theory, and maybe some live example of us using it, for example ICMP packet is used whenever we ping or Traceroute etc and then the practical aspect of it.
  • vik001ind
    MemberAug 4, 2010
    Wireshark is the best packet analysis tool, too commonly used in security field. linux & windows versions are available.
  • Manish Goyal
    MemberAug 7, 2010
    Sorry Guys for delay in reply
    I was busy with some work
    so let us try our first program that will show everything related to TCPPackets
    First execute this program then analyze its output and try to co-relate the output with your knowledge
    import jpcap.*;
    import jpcap.packet.*;
    import java.io.*;
    import jpcap.packet.TCPPacket.*;
    import java.io.*;
    class Network implements PacketReceiver
                String sp=null;
                String dp=null;
                String window=null;
                String sequence=null;
                String acknowledge=null;
                FileWriter ff=null;
                String da=null;
            public void receivePacket(Packet pt)
                try
                        if(pt instanceof TCPPacket)
                            TCPPacket tp=(TCPPacket)pt;
                            ff=new FileWriter("da.txt",true);
                            sp=new Integer(tp.src_port).toString();
                            dp=new Integer(tp.dst_port).toString();
                            window=new Integer(tp.window).toString();
                            sequence=new Long(tp.sequence).toString();
                            acknowledge=new Long(tp.ack_num).toString();
                            byte[]dat=tp.data;
                            da=new String(dat);
                            ff.write("\r\n Source port is :-"+sp);
                            ff.write("\r\n Desination port is:-"+dp);
                            ff.write("\r\n Sequence no is:-"+sequence);
                            ff.write("\r\n Acknowledgement no  is:-"+acknowledge);
                            ff.write("\r\n Status of rsv1 flag is:-"+tp.rsv1);
                            ff.write("\r\n Status of rsv2 flag is:-"+tp.rsv2);
                            ff.write("\r\n Status of Syn flag is:-"+tp.syn);
                            ff.write("\r\n Status of Urg flag is:-"+tp.urg);
                            ff.write("\r\n Status of Fin flag is:-"+tp.fin);
                            ff.write("\r\n Data :-"+da);
                            ff.write("\r\n");
                            ff.write("\r\n");
                            ff.close();
                catch(Exception e)
    public static void main(String args[])throws IOException
    int i;
    try
                  //print out its name and description
                  //print out its datalink name and description
                  System.out.println(" datalink: "+devices[i].datalink_name + "(" + devices[i].datalink_description+")");
                  //print out its MAC address
                  System.out.print(" MAC address:");
                  for (byte b : devices[i].mac_address)
                    System.out.print(Integer.toHexString(b&0xff) + ":");
                  System.out.println();
                  //print out its IP address, subnet mask and broadcast address
                  for (NetworkInterfaceAddress a : devices[i].addresses)
                    System.out.println(" address:"+a.address + " " + a.subnet + " "+ a.broadcast);
    JpcapCaptor captor=JpcapCaptor.openDevice(devices[0], 65535, true, 20);
    captor.loopPacket(-1,new Network());
    captor.close();
    catch(Exception e)
    create a file named da.txt at the same location where program resides .then execute this program
    Now open web browser and open any web page
    after opening web page ,open "da.txt"
    you will see the info about TCP packets that we have captured
  • Morningdot Hablu
    MemberAug 8, 2010
    Hello goyal,
    Firstly thanks for sharing code with us.
    I just try to compile your code it show error like this.
    Network.java:1: package jpcap does not exist
    import jpcap.*;
    Network.java:2: package jpcap.packet does not exist
    Network.java:5: package jpcap.packet.TCPPacket does not exist
    Network.java:7: cannot find symbol
    symbol: class PacketReceiver
    Network.java:17: cannot find symbol
    symbol : class Packet
    Network.java:21: cannot find symbol
    symbol : class TCPPacket
    Network.java:23: cannot find symbol
    Network.java:60: cannot find symbol
    symbol : class NetworkInterface
    symbol : variable JpcapCaptor
    Network.java:78: cannot find symbol
    symbol : class NetworkInterfaceAddress
    for (NetworkInterfaceAddress a : devices.addresses)
    Network.java:81: cannot find symbol
    symbol : class JpcapCaptor
    13 errors
    what i have to do to compile this code without any error.
    I am using using ubuntu 10.04 LTS.
  • Manish Goyal
    MemberAug 8, 2010
    have you installed Jpcap?
    If yes then you have to set environment for this ,I hope you had set environment for java also while installing it in ubuntu
    in same way you have set environment for this
    2:-Here again Once program will compile ,I don't think you will be able to capture packets
    since winpcap will not work in ubuntu which is must requirement for capturing packets
    i think you have to install libpcap(Not sure about spellings)
  • Manish Goyal
    MemberSep 6, 2010
    Sorry Guys for such a late response back on this thread
    So have you tried this program ? If yes do you got any idea ?
  • optimystix
    MemberSep 9, 2010
    i agree with vik. the simplest way to check info about the packets you send and receive is to use Wireshark. It is a popular tool used to study the network by amateurs as well as professionals.
    just download (around 17mb) and install the software, select the interface you want to capture which is usually your ethernet card, and select start. You can see live packets being captured and click on them to see a detailed list of information that they carry.
    you will be surprised to know that these can often show you the login ids and passwords or any info that you type online. this tool is often used for sniffing purposes .
  • Manish Goyal
    MemberSep 9, 2010
    Yeah i agree with you opti but i think there is more fun in creating our own tools .Even we can remove limitations of wireshark as it doesn't work for usb modems and atm network
