Linked Lists Questions
Saandeep Sreerambatla
@saandeep-sreerambatla-hWHU1M โ€ข Oct 9, 2024
This is the basic declaration we do while working on linked lists.
struct node {
int data;
struct node* next;
why is the next declared as a pointer? and not as a just
struct node next; ??
I will start with basic and then go for advanced questions.
  • aarthivg
    @aarthivg-HH344f • Mar 14, 2012
    English-ScaredThis is the basic declaration we do while working on linked lists.
    struct node {
    int data;
    struct node* next;
    linked list consist of two parts data and reference to the next node
  • Saandeep Sreerambatla
    @saandeep-sreerambatla-hWHU1M • Mar 14, 2012
    True, but the reference can also be accessed by normal variables using logic!
    and think in this perspective, is it valid if I declare
    struct node {
    int data;
    struct node next;
    If valid why dont we use, If invalid why is it invalid?
  • aarthivg
    The field of each node that contains the address of the next node is usually called the next link or next pointer.
    So reference cant be used as a normal variable.
    OK the answer I was expecting is,
    if we donot use a pointer, and declare a variable of struct node inside struct node, then compiler donot know how much memory to allocate to that variable as the parent structure declaration is not complete yet.
    if we use a pointer, then compiler knows that , its a pointer and it stores address of something . so it allocates memory.
  • greatcoder
    @greatcoder-Zo4hpf • Mar 15, 2012
    Here Because next is not a structure itself , it is a pointer to the next node in the linked list.
    @saandeep-sreerambatla-hWHU1M • Mar 17, 2012
    #-Link-Snipped-# Coder : Please elaborate!!
