linked list in C
durga ch
@durga-TpX3gO โ€ข Oct 26, 2024
OK!
I declare few nodes . lets say my node is named as sortElement.
now I want to store the memory locations of these nodes in an array
How do i declare that?
I tired something this way but I encountered an error in linux
struct sortElement
declaration;
sortElement *element[24];
what i am trying to do here is declare an array element which can store the locations of all my nodes
will this work?
  • Corpse-Thrust
    @corpse-thrust-NpL92W • Jun 2, 2009
    I guess C doesn't support creating pointers to custom data types. Only C++ does.
    Try creating a pointer of type void and using it to store the memory locations of the nodes.
  • pradeep_agrawal
    @pradeep-agrawal-rhdX5z • Jun 2, 2009
    Corpse-ThrustI guess C doesn't support creating pointers to custom data types. Only C++ does.
    C language do support creation of pointers to user defined data type. Below is one of the CE posts where i have defined pointer to user defined data type in C:
    durgaI declare few nodes . lets say my node is named as sortElement.
    struct sortElement
    declaration;
    will this work?
    The above code will not work due to two reasons:
    1. The declaration inside the body of struct should be a valid variable declaration (e.g., "int declaration;").
    2. You are trying to create an array of pointers to sortElement, but sortElement is not a valid data type. The valid type is "struct sortElement" or you need to define a data type using typedef.
    The declaration should be as:
    struct sortElement {
      int declaration;  //or something else as required
    struct sortElement *element[24];
    or
    typedef struct {
    } sortElement_t;
    sortElement_t *element[24];
    Let us know if you face issue with above change.
    -Pradeep
  • durga ch
    @durga-TpX3gO • Jun 2, 2009
    Hi CT, Pradeep,
    Thanks for the reply.
    Firstly 'declaration' is not my variable. I have list of declarations and I did do typedef
    The actual code is as below:
    typedef struct sortElement sortElement;
    struct sortElement
    int elementnumber;
    int topflag;
    int bottonflag;
    sortElement *zero;
    sortElement *one;
    struct inputbuf1;
    struct inputbuf2;
    struct outputbuf1;
    struct outputbuf2;
  • pradeep_agrawal
    As you are declaring correct variables inside the body of struct so there is only one issue is the declaratio
    is not correct. The declaration should be as:
      //variable declaration
    or
    typedef struct {
    } sortElement_t;
    -Pradeep
  • durga ch
    thanks! But what is wrong with "typedef struct sortElement sortElement;"
    is it not same as saying take "struct sortElement" as sortElement?
    P.S: I have few more syntax related questions to ask, is it OK if I continue int his thread?
    Thansk again!
  • pradeep_agrawal
    durgathanks! But what is wrong with "typedef struct sortElement sortElement;"
    When we declare a struct as
    struct structName {
      //declaration of variables
    The declaration of variable of the above type will look like:
    struct structName xyz;
    As per C syntax you can not declare a variable as "structNamexyz ;" because structName is currently not a data type "struct structName" is a data type.
    'typedef' can be used to define a data type to avoid using 'struct' with 'structName' while you are declaring variables.
    The typedef will look like:
    typedef struct structName {
    } structName_t;
    Here i have defined a data type structName_t of type "struct structName". Now you can use "structName_t" instead of "struct structName".
    The declaration of variable using the newly defined data type can be done as:
    structName_t xyz;
    Let me know if any item need more clarification.
    P.S.: For query on different topic start new thread.
    -Pradeep
  • durga ch
    got it! thanks for that
