Line follower using the pic16f877
preeste
@preeste-Q3d5XK โ€ข Oct 21, 2024
hey there....i am looking to build a line follower using the pic16f877.....i plan on using red leds and phototransistors for my sensors and also want to use the whole concept of differential drive for moving my motors using only 2 wheels. can anyone please help me.....i dont know how to start, dont know what components i will need etc....please help.....does anyone have a schematic available for such a project? please help....am desperate.....thanks a lot in advance
  • preeste
    @preeste-Q3d5XK Nov 1, 2007
    oh yeas....i want to also use geared motors, 5 sensors using thered leds and OP505B phototransistors.......furthermore i want to use the L293D h-bridge to control motor....can someone help me with a design for the line follower with all the above requirements......i will be so greatful......please its urgent....like i need it if its possible in the next two days maximum....thanks again
  • preeste
    @preeste-Q3d5XK Nov 3, 2007
    Can someone please help? 4 days and no help! ๐Ÿ˜”
    @thebigk Nov 4, 2007
    preesteCan someone please help? 4 days and no help! ๐Ÿ˜”
    Replies will take some time. You will have to be bit patient!
    -The Big K-
  • John Connor
    @john-connor-U8snPq Nov 28, 2007
    look this link
    replace the pic for the 16f877
    and configure this code in the pic
    DEFINE LOADER_USED 1
    J VAR BYTE
    SYMBOL ENAL = PORTB.0
    SYMBOL ENAR = PORTB.1
    SYMBOL LAMOT = PORTB.2
    SYMBOL LBMOT = PORTB.3
    SYMBOL RAMOT = PORTB.4
    SYMBOL RBMOT = PORTB.5
    RIR0 VAR BYTE
    RIR1 VAR BYTE
    RIR2 VAR BYTE
    RIR3 VAR BYTE
    TRISB = 0
    ADCON1 = $00
    J = 240
    INI:
    ADCIN 0,RIR0
    ADCIN 1,RIR1
    ADCIN 2,RIR2
    ADCIN 3,RIR3
    INICIO:
    IF RIR0 > J AND RIR1 > J AND RIR2 > J AND RIR3 > J THEN INI
    IF RIR0 <= J AND RIR1 <= J AND RIR2 <= J AND RIR3 <= J THEN INI
    IF RIR0 > J AND RIR1 > J AND RIR2 <= J AND RIR3 <= J THEN FORWARD
    IF RIR0 > J AND RIR1 > J AND RIR2 > J AND RIR3 > J THEN FORWARD
    IF RIR0 > J AND RIR1 <= J AND RIR2 <= J AND RIR3 <= J THEN BACK
    IF RIR0 <= J AND RIR1 > J OR RIR2 > J OR RIR3 > J THEN BACK
    IF RIR0 > J AND RIR1 > J AND RIR2 > J AND RIR3 <= J THEN LEFT
    IF RIR0 <= J AND RIR1 > J AND RIR2 > J AND RIR3 <= J THEN LEFT
    IF RIR0 > J AND RIR1 > J AND RIR2 <= J AND RIR3 > J THEN RIGHT
    IF RIR0 <= J AND RIR1 > J AND RIR2 <= J AND RIR3 > J THEN RIGHT
    IF RIR0 > J AND RIR1 <= J AND RIR2 > J AND RIR3 <= J THEN MAXLEFT
    IF RIR0 <= J AND RIR1 <= J AND RIR2 > J AND RIR3 <= J THEN MAXLEFT
    IF RIR0 > J AND RIR1 <= J AND RIR2 <= J AND RIR3 > J THEN MAXRIGHT
    IF RIR0 <= J AND RIR1 <= J AND RIR2 <= J AND RIR3 > J THEN MAXRIGHT
    goto INI
    FORWARD:
    ENAL = 1
    ENAR = 1
    LAMOT = 1
    LBMOT = 0
    RAMOT = 0
    RBMOT = 1
    GOTO INI
    BACK:
    ENAL = 1
    ENAR = 1
    LAMOT = 0
    LBMOT = 1
    RAMOT = 1
    RBMOT = 0
    GOTO INI
    LEFT:
    ENAL = 1
    ENAR = 0
    LAMOT = 1
    LBMOT = 0
    RAMOT = 1
    RBMOT = 0
    GOTO INI
    RIGHT:
    ENAL = 0
    ENAR = 1
    LAMOT = 0
    LBMOT = 1
    RAMOT = 0
    RBMOT = 1
    GOTO INI
    MAXLEFT:
    ENAL = 1
    ENAR = 1
    LAMOT = 1
    LBMOT = 0
    RAMOT = 1
    RBMOT = 0
    GOTO INI
    MAXRIGHT:
    ENAL = 1
    ENAR = 1
    LAMOT = 0
    LBMOT = 1
    RAMOT = 0
    RBMOT = 1
    GOTO INI
    END
    TAKE CARE
    ATT
    JOHN CONNOR
  • jmn
    jmn
    @jmn-H5FsIf Dec 24, 2007
    I am building a line follower. I use a pic16f877a to read the sensors and to control the motors. To drive the motors I use a l298, line sensors: CNY70, differential drive with tamiya gearbox.
    This is the robot if this can help you..
    <a href="https://www.flickr.com/photos/11711916@N06/" target="_blank" rel="nofollow noopener noreferrer">pic16f690 | Flickr</a>
    I am testing now the pcb and programming the pic. Tamiya gearbox is a good way to build the differential drive, it is cheap an fast.
