@reachrkata-FOcqhH • Oct 31, 2009
Try photodiodes / Phototransistors.
-Karthik -
@cooltwins-I5yJpZ • Nov 1, 2009
i am not sure about this but will LDR (Light dependent resistor) work
i used it once to find the change in amount of light falling on it -
@madhura-hegde-amg6BJ • Nov 1, 2009
thanks a lot frendz......if i face any prob then surely approach again...😛
@sumanmathad-EVll15 • Nov 4, 2009
i am new here.. i am in first sem
eee is realy tough for me .. please tell me how to cop with and also how to do projects![[IMG]](proxy.php?image=http%3A%2F%2Fwww.crazyengineers.com%2Fforum%2Fimages%2Ficons%2Ficon5.gif&hash=bab10f229c94d466962b24372bd0eebe)
@distrito-tthB6v • Dec 4, 2009
color sensor project
I am new to eee. We have a color sensor lab project.
Photoresistors, LED diodes, opamps should be used.
Can you please help with its circuit? -
@cranky-E9J79q • Dec 5, 2009
Use LED in f/b,photodiode(or LDR*) in r/b (don't forget to connect resistors in series with both components)..
connect the voltage across photodiode to one input of op-am and the other input will be a reference(use potentiometers for that)..connect other terminals of op-am to battery terminals(positive and negative)...
Your sensor is ready..depending on whether white or black surface the voltage across photodiode is going to change and hence the output
*LDR are sensitive to atmospheric light so photodiodes will be a better option..however,make sure your photodiodes work well..and there is no biasing in case of LDR's
Any doubt please ask😁 -
@electronicsunzz-72SDL7 • Dec 5, 2009
hi ,
moreover one can increase the sensitivity of the sensor by not letting other light falling on the light dependent resister expect the light we desired to sense.
this gives the accurate change in the resistance with respect to the desired light which we want to sense. -
the distance between the led and diode should be very less..the angle of cone should be less than equal to six degree for more sensitivity😁
@distrito-tthB6v • Dec 7, 2009
thanks a lot for your assistance friends.
our sensor has to display three detected colors seperately. RGB.
So, does this mean that photoresistors can be used as brightness sensor?
When red light from the LED for example, shines on red and green objects, the light will be reflected more by red object compared to the green object. So can this sensor measure the brightness of the reflected wave and sense that the red object brighter than the green one?
I hope this is a good approach. I need a confirmation from you, please.
It seems thatI will need to use more than one op-amp. How will I calibrate the sensing of the three colors?
Red Green Blue LEDs should turn on when sensing red, green, blue colors respectively.
thanks beforehand
