@jeffrey-xA7lUP • Oct 9, 2012
Latch is a form of Flip flop which does not use the edge of the pulse as triggering center
It needs a levelled input to trigger
Whereas a flip flop uses only the edges for triggerring which makes it more advantageous to use it than latch in many applications -
@prototype-G9Gn5k • Oct 9, 2012
Flipflop have clock and latch domt have clock. NEVER SAY THAT IF THIS QUESTION IS ASKED!
Difference is, what Jeffery said, in simple words, flop is edge triggered while latch is level triggered. -
@arunchary-VtqB3c • Oct 10, 2012
exactly all are above are saying right.latch is level triggered and flipflop is an edge triggered.but both are considered as logical device to implement the task.
@pratap-singh-6xlmve • Nov 28, 2012
to add to the above remember that a latch is the basic structural unit of a rather complex flip flop(just like cells in our body); flip flops with different functionality could be developed by logically connecting latches and then supplying a clock source at the input ends. in addition flip flops can also be level trigered though they are not usually put in that configuration, the reason being that they are sophisticated and require finite timing sequences to change their states.
every latch is a flip flop but the converse is not true.
however both remain digital logic implementing circuits/devices -
@solar-morpher-SAx0di • Nov 29, 2012
proffyevery latch is a flip flop but the converse is not true.
however both remain digital logic implementing circuits/devicesEven the forward is not true as every latch is a flip flop until a first transition occurs in the output. But due to races the statement is not widely used. But to an extent we can say it is a reality
