Laminations of steel for motor
NAVATHE SACHIN
@navathe-8fNDWG โ€ข Oct 26, 2024
Hi guys
Why iron core is thin & laminated in motor instead of solid core ?
For most of the applications in motors or transformers, silicon steel material is used for iron core ?
Why only these material is suitable for iron core ?
What kind of properties should a perfect iron core should have ?
Guys Im from mechanical background please help..
Thanks in advance.
    @ramani-VR4O43 • Oct 29, 2016
    The core must be a perfect path for the magnetic field but electrically insulating for minimal eddy current losses. Details are available in many text books and the net. This will start you with some basics:
  • Tribikram Mishra
    @tribikram-fk8ijK • Nov 2, 2016
    Hi Sachin
    Well iron Cores are prefered in Electrical equipments due to their high ferro magnetic effects.
    It provides perfect path for magnetic field.
    As you know Electricity & Magnetism are inseparable.
    The Iron Sheets are laminated so as to reduce <a href="https://circuitglobe.com/what-is-eddy-current-loss.html" target="_blank" rel="nofollow noopener noreferrer">What is Eddy Current Loss? - definition and expression - Circuit Globe</a> in the system.
    The Suitable properties are linked #-Link-Snipped-#.
    Have a Look.
    Thank You .
  • NAVATHE SACHIN
    @navathe-8fNDWG • Nov 9, 2016
    Thank you... #-Link-Snipped-# sir and ...@ Tribikram Mishra.
