lab experiments for civil engineers
krishthegod
@krishthegod-LBbOyV • Oct 25, 2024
hi guys,
well here are some lab experiments foe civil students... well it might help u ...
TESTS ON CEMENT FINENESS​ AIM​ To determine the fineness of cement by dry sieving as per​ IS: 4031 (Part 1) - 1996.​ PRINCIPLE​ The fineness of cement is measured by sieving it through a​ standard sieve. The proportion of cement, the grain sizes of​ which, is larger than the specified mesh size is thus determined.​ APPARATUS​ i) 90μm IS Sieve​ ii) Balance capable of weighing 10g to the nearest 10mg​ iii) A nylon or pure bristle brush, preferably with 25 to 40mm​ bristle, for cleaning the sieve​ PROCEDURE​ i) Weigh approximately 10g of cement to the nearest 0.01g and​ place it on the sieve.​ ii) Agitate the sieve by swirling, planetary and linear​ movements, until no more fine material passes through it.​ iii) Weigh the residue and express its mass as a percentage R1,​ of the quantity first placed on the sieve to the nearest 0.1​ percent.​ iv) Gently brush all the fine material off the base of the sieve.​ v) Repeat the whole procedure using a fresh 10g sample to​ obtain R2. Then calculate R as the mean of R1 and R2 as a​ percentage, expressed to the nearest 0.1 percent. When the​ results differ by more than 1 percent absolute, carry out a​ third sieving and calculate the mean of the three values.​ REPORTING OF RESULTS​ Report the value of R, to the nearest 0.1 percent, as the residue​ on the 90μm sieve.​ ​ CONSISTENCY​ AIM​ To determine the quantity of water required to produce a cement​ paste of standard consistency as per IS: 4031 (Part 4) - 1988.​ PRINCIPLE​ The standard consistency of a cement paste is defined as that​ consistency which will permit the Vicat plunger to penetrate to a​ point 5 to 7mm from the bottom of the Vicat mould.​ APPARATUS​ i) Vicat apparatus conforming to IS: 5513 - 1976​ ii) Balance, whose permissible variation at a load of 1000g​ should be +1.0g​ iii) Gauging trowel conforming to IS: 10086 - 1982​ 3​ PROCEDURE​ i) Weigh approximately 400g of cement and mix it with a​ weighed quantity of water. The time of gauging should be​ between 3 to 5 minutes.​ ii) Fill the Vicat mould with paste and level it with a trowel.​ iii) Lower the plunger gently till it touches the cement surface.​ iv) Release the plunger allowing it to sink into the paste.​ v) Note the reading on the gauge.​ vi) Repeat the above procedure taking fresh samples of cement​ and different quantities of water until the reading on the​ gauge is 5 to 7mm.​ REPORTING OF RESULTS​ Express the amount of water as a percentage of the weight of​ dry cement to the first place of decimal.​ ​ INITIAL AND FINAL SETTING TIME​ AIM​ To determine the initial and the final setting time of cement​ as per IS: 4031 (Part 5) - 1988.​ APPARATUS​ i) Vicat apparatus conforming to IS: 5513 - 1976​ ii) Balance, whose permissible variation at a load of 1000g​ should be +1.0g​ iii) Gauging trowel conforming to IS: 10086 - 1982​ PROCEDURE​ i) Prepare a cement paste by gauging the cement with 0.85​ times the water required to give a paste of standard​ consistency (see consitency)​ ii) Start a stop-watch, the moment water is added to the​ cement.​ iii) Fill the Vicat mould completely with the cement paste​ gauged as above, the mould resting on a non-porous plate​ and smooth off the surface of the paste making it level with​ the top of the mould. The cement block thus prepared in the​ mould is the test block.​ A) INITIAL SETTING TIME​ Place the test block under the rod bearing the needle.​ Lower the needle gently in order to make contact with the​ surface of the cement paste and release quickly, allowing it​ to penetrate the test block. Repeat the procedure till the​ needle fails to pierce the test block to a point 5.0 ± 0.5mm​ measured from the bottom of the mould.​ The time period elapsing between the time, water is added​ to the cement and the time, the needle fails to pierce the​ test block by 5.0 ± 0.5mm measured from the bottom of the​ mould, is the initial setting time.​ B) FINAL SETTING TIME​ Replace the above needle by the one with an annular​ attachment.​ The cement should be considered as finally set when, upon​ applying the needle gently to the surface of the test block,​ the needle makes an impression therein, while the​ attachment fails to do so. The period elapsing between the​ time, water is added to the cement and the time, the needle​ makes an impression on the surface of the test block, while​ the attachment fails to do so, is the final setting time.​ REPORTING OF RESULTS​ The results of the initial and the final setting time should be​ reported to the nearest five minutes.​ ​ SOUNDNESS​ AIM​ To determine the soundness of cement by Le-Chatelier method​ as per IS: 4031 (Part 3) - 1988.​ APPARATUS​ i) The apparatus for conducting the Le-Chatelier test should​ conform to IS: 5514 - 1969​ ii) Balance, whose pemissible variation at a load of 1000g​ should be +1.0g​ iii) Water bath​ PROCEDURE​ i) Place the mould on a glass sheet and fill it with the cement​ paste formed by gauging cement with 0.78 times the water​ required to give a paste of standard consistency (see​ consitency).​ ii) Cover the mould with another piece of glass sheet, place a​ small weight on this covering glass sheet and immediately​ submerge the whole assembly in water at a temperature of​ 27 ± 2oC and keep it there for 24hrs.​ iii) Measure the distance separating the indicator points to the​ nearest 0.5mm (say d l ).​ iv) Submerge the mould again in water at the temperature​ prescribed above. Bring the water to boiling point in 25 to 30​ minutes and keep it boiling for 3hrs.​ v) Remove the mould from the water, allow it to cool and​ measure the distance between the indicator points (say d 2 ).​ vi) (d 2 – d l ) represents the expansion of cement.​ REPORTING OF RESULTS​ Calculate the mean of the two values to the nearest 0.5mm to​ represent the expansion of cement.​
  • mrtvine
    @mrtvine-qlEN1w • Feb 24, 2010
    Hi krishthegod,
    Thank you for sharing your experience in lab testing especially using other technical standard other than BS, ASTM, AS, etc. Hmm...good knowledge to know your standard specification. I normally used British Standard and few ASTM in lab testing... Hope to learn other standard as well...
    Regards,
    mrtvine
    #-Link-Snipped-# [FONT=&quot][/FONT]
  • krishthegod
    @krishthegod-LBbOyV • Feb 24, 2010
    ya thank you..wel wil post many interesting topics\
    view my blog...
    https://krishthegod.blogspot.com/
