  • KONE UltraRope Using Elevators Can Go The Extra Kilometre In High Rise Buildings
    @abrakadabra
    Updated: Oct 26, 2024
    Views: 1.3K
    KONE, the elevator manufacturer from Finland, is here with innovation in the high-rise elevator technology. With KONE UltraRope in place, now elevators that will be able to travel 1 kilometer-twice the distance that is currently feasible, have been made possible. This light-weight yet strong UltraRope is made up of carbon fiber that is more durable and stronger than any conventional steel rope. One of the lingering technical issues with very tall buildings is the weight that elevator cables need to be able to support the weight of a fully-loaded car can increase by around three times for every 500 meters it climes.
    slide
    In order to solve this problem, as there's been a steep rise in the length of buildings in recent times, KONE has been working on a new technology which could enable skyscrapers to go even higher than currently possible. UltraRope has been under development since 2010 and has been tested in KONE’s Tytyri underground facility. The company's now got a high-friction coating on the rope to dramatically reduce the elevator’s moving masses. This coating doubly advantageous because it doesn’t require lubrication and therefore fosters increased sustainability. Way to go, elevators!
  • lovebox
    MemberJun 22, 2013
    A nice development. I think that the UltraRope can also be put to use in cranes that are used in the construction of the very same high-rise buildings in which such elevators are to be installed.
    Moreover, this UltraRope may also be used in the 'Rocking-Horse' mechanism that is used to pump out crude oil from great depths in an oil well.
    This would serve to increase the productivity. What do you guys think?
  • just2rock
    MemberJun 23, 2013
    soon using carbon nanofibre ropes will even travel to outer space...and its been tested even in lab..😏
  • Anil Jain
    MemberJun 23, 2013
    The Kingdom tower (Jeddah) is in making and the tower is expected to be over 1 KM tall. I would be interesting to see which elevator do they use. Will they believe on this in the ultra high tower?
    Also, any one anyclue if Burj Dubai has any elevator which goes from bottom most to top. If Yes, which elevator is that?
    -CB
  • KSS Manian
    MemberJul 4, 2013
    In the present tallest building. they are using Mitusubishi elevators
    AdministratorJul 4, 2013
    KSS manian
    Burj Khalifa has elevators built by OTIS. Mitsubishi Elevators were set up in the Taipei Towers 101.
  • KSS Manian
    MemberJul 4, 2013
    oooohhhh, thank you for correcting me
