@deepmali-wmuTGc • Feb 16, 2009
hi
I am also doing something similar..I am using SVD based approach...If you have any info pls post it here. -
sherly OP
@sherly-WEz2GR • Feb 23, 2009
classification rate
hi,
I am working on image classification.
I am using minimum distance classifier.
Can anyone help me with the formula for correct classification rate.
Thank you. -
@predictor-lfVrRm • Mar 14, 2009
Re: classification rate
sherlyhi,
Can anyone help me with the formula for correct classification rate.I think that what you are referring to is simply the accuracy of the classifier, which is defined as: the number of correct classifications divided by the total number of classifications.
-Will Dwinnell
<a href="https://matlabdatamining.blogspot.com/" target="_blank" rel="nofollow noopener noreferrer">Data Mining in MATLAB</a> -
sherlyhi
i am working in classification of texture images.
can anyone help me with a code for k nearest neighbour classifier and also help me to create a training dataset with labelled categories.k-nearest neighbors is very simple:
1. Calculate the distance from the current case to all historical cases.
2. Select the k historical cases with the least distance from the current case.
3. Merge those k cases, typically by averaging for numeric estimation problems or by voting for classification problems.
-Will Dwinnell
