JAVA related problems
Neha
@neha-3vibjn โ€ข Oct 25, 2024
Hi everyone,
I am learning JAVA these daz...My teacher is teaching me Applets these daz..Its quite interesting.
As I said I found Applets interesting,I was trying to create a web page but I don't know how to increase the font size of a Label...Can anyone help me out??
  • sravik
    @sravik-QaGqty • Aug 1, 2006
    hi dere !
    i saw ur problem, i can help u out..dont worry bout tat.
    ok to increase ur font size u need to use a method named setFont().
    setFont() method takes Font class object as argument. think little bit confusing rite..dont worry i will let u know by an example..
    consider
    Label l = new Label("Neha");
    Font f = new Font("verdana", Font.BOLD, 40);
    l.setFont(f);
    add(l);
    now dis will help u 2 hav a label of size 40, bold with verdana font.
    ok tats it. i think now it will b clear 4 u..hey as soon as xceute it let me know ok..anyways dis is ravi(sravik) presently in toronto, canada doing my MS.
  • Neha
    @neha-3vibjn • Aug 1, 2006
    thanx a ton...who needs a tutor wen CE is there!!๐Ÿ˜‰
    @thebigk • Aug 3, 2006
    Way to go CEans! [โ€‹IMG]
    The Big CE-Dream is coming into reality.
    -The Big K-
  • Neha
    @neha-3vibjn • Aug 4, 2006
    Can you tell me,how to set the font color of Label...wud COLor.red work??
  • Neha
    @neha-3vibjn • Aug 10, 2006
    I have got the answer to my question..the font color can be set by using setForeground(Color.red)
  • Neha
    @neha-3vibjn • Aug 14, 2006
    using class object in Label
    How can we use the object of class in label?
    To make my question more clear, I have defined a class "time" which contains the time counter for 30minutes and I want to use its object in label.
  • Neha
    @neha-3vibjn • Aug 19, 2006
    JTable...
    I wanna enter data in JTable in a specific row and column.
    Any help??
  • sravik
    @sravik-QaGqty • Aug 20, 2006
    inserting data at specific rows and columns
    hi dere !
    here is an example for your query. just have a look at this sample code.
    JTable t = new JTable(5,5); // creates table with 5 rows and 5 columns
    t.setValueAt(10,2,2); // set value 10 at 2nd row and 2nd column.
    do remember that the table is like two dimensional array. i mean 2 say that the rows and columns start at 0,0 and ends at m-1, n-1.
    setValueAt(Object, rows, columns).. hav a look at the parameters.
    hope you can implement it now.
  • Neha
    @neha-3vibjn • Aug 21, 2006
    Thanx!!
    Can u tell me how can I color a specific cell i.e. 3*3 table in a 9*9 table and how can we resize an image?
    Thanx in advance๐Ÿ˜‰
  • sravik
    @sravik-QaGqty • Aug 22, 2006
    about table ๐Ÿ˜€
    hi dere !
    ur class should extend DefaultTableCellRenderer and use the method
    public Component getDefaultTableCellRendererComponent(JTable table, Object value, boolean isSelected, boolean focus, int row, int col) method.
    here is an example. dis example takes the the table , the vavle, the row, column and checks whether the row is 3 and column is 3. if this condition is true the cell background color is set to red. the concept of CellRenderer is very very important.
    import java.awt.*;
    import javax.swing.*;
    import javax.swing.table.*;
    public class CustomTableCellRenderer extends DefaultTableCellRenderer
    public Component getTableCellRendererComponent
    boolean hasFocus, int row, int column)
    Component cell = super.getTableCellRendererComponent
    (table, value, isSelected, hasFocus, row, column);
    if( row==3 && column==3)
    cell.setBackground(Color.red);
    return cell;
  • sravik
    @sravik-QaGqty • Aug 23, 2006
    resizing image ๐Ÿ˜€
    hi dere !
    this is regarding resizing the image.
    ok, you can use getScaledInstance method present the java.awt.Image .
    the syntax is
    public Image getScaledInstance(itn width, int height, int hints);
    this method creates a scaled version of the your image into new Image object.
    hope now you can use this method for resizing.
    Happy Programming
  • Neha
    @neha-3vibjn • Aug 24, 2006
    Thanx Sravik.
    I'll try it out.
  • Neha
    @neha-3vibjn • Nov 10, 2006
    Re: about table ๐Ÿ˜€
    sravikhi dere !
    import java.awt.*;
    return cell;
    My class already extends JFrame, how can I make it to extend DefaultCellRenderer as one class can iextend a single class only?
    Reply as soon as possible..
  • jatin
    @jatin-dvzGIf • Nov 13, 2006
    hi neha
    u know web designing
    i know a bit except java can u pls help me to understand java.
    i want to start java frm vry basic
    pls help
  • Varsha0802
    @varsha0802-YohNRX • Sep 26, 2010
    hi...........i have a doubt. i want to take an array of integer values as input using command line arguments. how can i do it?
  • Manish Goyal
    @manish-r2Hoep • Sep 26, 2010
    Hi varsha
    Please ask you question in separate thread in computer science section
