java program to add three numbers in java using inheritance..please help
zion
@zion-6KgmEO • Oct 25, 2024
class A
int a;
int b;
class B extends A
int c;
class C extends B
int d;
public int sum()
d=a+b+c;
return d;
class add
A obj1= new A();
B obj2= new B();
C obj3= new C();
obj1.a = 1;
obj1.b = 2;
obj2.c = 3;
System.out.println("sum is"+obj3.sum());
the output it showed was sum is 0
then i wrote again the code
class A
int a;
int b;
void showab()
System.out.println(a+b);
class B extends A
int c;
void showc()
System.out.println(c);
class C extends B
int d;
public int sum()
d=a+b+c;
return d;
class add1
A obj1= new A();
B obj2= new B();
C obj3= new C();
obj1.a = 1;
obj1.b = 2;
obj1.showab();
obj2.c = 3;
obj2.showc();
obj3.sum();
output showed was 3,3 sum is 0
can anyone plz tell what mistake i made in my two programs and what basic i m lacking that garbage value i,e 0 comes again n again what methodology should i adopt to overcome this.
    @anoop-kumar-GDGRCn • May 27, 2012
    package sample;
    class A {
    int a;
    int b;
    class B extends A {
    int c;
    class C extends B {
    int d;
    public int sum() {
    d = a + b + c;
    return d;
    public class add {​public static void main(String args[]) {​A obj1 = new A();​B obj2 = new B();​C obj3 = new C();​obj3.a = 1; // you ware creating object from obj1 and obj2 and then​obj3.b = 2; //putting values in these and then calling obj3 😲​obj3.c = 3;​System.out.println("sum is" + obj3.sum());​}​}​
    ​and value 0 is not garbage value its default value of class member of Integer type that is 0.​
  • zion
    @zion-6KgmEO • May 27, 2012
    thanx......
  • zion
    what is use or need to create object for A and B..we can directly create for C
    zionwhat is use or need to create object for A and B..we can directly create for C
    You got that.. there is no use now... 😀
  • zion
    @zion-6KgmEO • May 28, 2012
    thanx😀
  • oyetayo micheal
    @oyetayo-fw1jxD • Feb 26, 2019
    why it is that multiple inheritance is not allowed in java except when dealing with interface
