  • komputergeek
    @komputergeek-Yf5hJ4 • Apr 15, 2009
    Post your code here.
  • sahilgandhi87
    @sahilgandhi87-jf94Wy • Apr 15, 2009
    komputergeekPost your code here.
    Here first i am providing the whole directory structure and that is followed by coding of .java files.
    My directory structure is:
    C:
    MyProjects: (this is folder) EVERYTHING followed by ":" is folder
    beerV1:
    src:,classes: (sub-folders of berV1)
    src folder contains:
    src:
    com:
    example:
    web:,model: (sub-folders of example)
    web folder contains:
    BeerSelect.java (file)
    model folder contains:
    BeerExpert.java (file)
    similarlly classes folder contains:
    classes:
    com:
    example:
    web:,mode:l
    web:
    (this folder does not contain file yet.BeerSelect.class file goes here after successful compilation)
    model:
    BeerExpert.class
    now when i compile BeerSelect.java like:
    C:\MyProjects\beerV1>javac -classpath C:/tomcat/common/lib/servlet-api.jar -d classes src/com/example/web/BeerSelect.java
    Three ERRORs:
    src/com/example/web/BeerSelect.java:3: package com.example.model does not exist
    import com.example.model.*;
    src/com/example/web/BeerSelect.java:17: cannot find symbol
    symbol : class BeerExpert
    BeerExpert be = new BeerExpert();
    3 errors
    BeerExpert.java has code:
    package com.example.model;
    import java.util.*;
    public class BeerExpert
    public List getBrands(String c)
    List<String> arr = new ArrayList<String>();
    if(c.equals("amber"))
    arr.add("Jack Amber");
    arr.add("Red Moose");
    else
    arr.add("Jail Pale Ale");
    arr.add("Gout Strout");
    return(arr);
    BeerSelect.java has code:
    package com.example.web;
    import javax.servlet.*;
    import javax.servlet.http.*;
    import java.io.*;
    import java.util.*;
    public class BeerSelect extends HttpServlet
    public void doPost(HttpServletResponse response,
    HttpServletRequest request)
    throws IOException,ServletException
    String c = request.getParameter("color");
    List a = be.getBrands(c);
    response.setContentType("text/html");
    PrintWriter out = response.getWriter();
    out.println("Selection Beer Advice<br> ");
    Iterator i = a.iterator();
    while(i.hasNext())
    out.println("<br> try: "+ i.next());
    MAIN PROBLEM LIES WITH IMPORTING OF PACKAGE IN BeerSelect.java
    and ERROR is Package not exist but it exist...
  • arunhero99
    @arunhero99-LRZv4M • Apr 16, 2009
    Beer example eh? Surely Head First series ๐Ÿ˜›
    I have seen this error in java forums.
    the example is linux format. Use windows format:
    javac -classpath C:\tomcat\common\lib\servlet-api.jar;
    Try adding semicolons to separate classpaths...
