Java: Is "reference variable of a class" same as "an object of that class"?
In context to Java programming,
Also for a code like
class Sample
int a, b;
public static void main(String arg[])
int c;
// other statements
Among the variables a,b, c which are the class variables.
Is there a difference between variable a/b and variable c as far as their scope is concerned?
    @anoop-kumar-GDGRCn • Feb 18, 2016
    I assume you like to know the difference between, Instance variable and local variable.
    There is certainly scope difference between variable "a" and "c".
    "a/b" are class/instance variables .
    "c" is a local variable defined inside the method.
    scope of "a/b" is associated to instance of class, object, just like method, in your program main() method.
    Better go through full tutorial of varial type and do some practice.
    <a href="https://www.tutorialspoint.com/java/java_variable_types.htm" target="_blank" rel="nofollow noopener noreferrer">Java - Variable Types</a>
    You question is confusing, what exactly you are looking far?
