  • JAVA-IN-LINUX
    Updated: Oct 25, 2024
    Views: 1.3K
    Hi,
    i want to know where to write a java program in linux(i am running centos operating system),i should write in a file ,from command line or in the folders.
    i want to know how to run a java program in linux,thanks😀
    NITISH CSE JHS
    You can use editors like : emacs,gedit,GVim,etc.
    (I prefer emacs)
    NITISH CSE JHS
    -Press ctrl+alt+T : Opens the Terminal
    -cd to directory where program is saved.(I assume you know this)
    - Type in terminal
    javac NameOfFile.java
    Note: For javac,you have to install OpenJDK-devel.
    Note2: If you don't like compiling programs from terminal,you can use IDE like Eclipse.
  • NITISH CSE JHS
    MemberApr 21, 2013
    Abhishek Rawal
    (I prefer emacs)
    - Type in terminal
    thanks a lot sir
  • Anand Tamariya
    MemberApr 22, 2013
    For any serious Java developer, knowledge of an IDE (eclipse, netbeans or RAD) is a must. These are available for Linux too. You should start from there.
