Java: Could not find run time environment
sulochana anand
sulochana anand
@sulochana-anand-OrGmKr Oct 21, 2024
i installed java and set parh.but when i m compiling with javac it is giving an error --could not find run time enviornment ,and java.dll.what should i do any one please help me.
  • Neeraj Sharma
    Neeraj Sharma
    @neeraj-iAaNcG Sep 3, 2012
    Check your java folder in C:/Program Files or wherever you have installed it. Are you able to see two folders named jdk and jre there?
  • clZazy
    clZazy
    @clzazy-zEzTWl Sep 3, 2012
    first thing check whether you installed JRE or not.
    if you have already installed JRE and getting this error then there could be a version problem which the error shows.
  • clZazy
    clZazy
    if you are still getting problem then just check out this link. I am sure it will help.
    <a href="https://www.newatlanta.com/c/products/bluedragon/self_help/faq/detail?faqId=6" target="_blank" rel="nofollow noopener noreferrer">BlueDragon Self-Help: FAQ</a>
  • sulochana anand
    sulochana anand
    @sulochana-anand-OrGmKr Sep 3, 2012
    thanks all i could run it
