@sonisapan-I2Sw1d • Mar 5, 2013
can u give us the exam detail link? IN which month exam is conducted?
@bithamang-9pwN1D • Mar 5, 2013
here is the link
#-Link-Snipped-# -
@rising-star-MFwHIe • Apr 24, 2013
can u tell me the syllabus for ISRO CS exam .... As per my knowledge syllabus is as follows:
Computer H/W Digital Logic: Logic functions, Minimization, Design and synthesis of Combinational and Sequential circuits -- Number representation and Computer Arithmetic (fixed and floating point)
Computer Organization: Machine instructions and addressing modes, ALU and Data-path, hardwired and micro-programmed control, Memory interface, I/O interface (Interrupt and DMA mode), Serial communication interface, Instruction pipelining, Cache, main and secondary storage.
SOFTWARE SYSTEMS Data structures: Notion of abstract data types, Stack, Queue, List, Set, String, Tree, Binary search tree, Heap, Graph --
Programming Methodology: C programming, Program control (iteration, recursion, Functions), Scope, Binding, Parameter passing, Elementary concepts of Object oriented, Functional and Logic Programming --
Algorithms for problem solving: Tree and graph traversals, Connected components, Spanning trees, Shortest paths -- Hashing, Sorting, Searching -- Design techniques (Greedy, Dynamic Programming, Divide-and-conquer) --
Compiler Design: Lexical analysis, Parsing, Syntax directed translation, Runtime environment, Code generation, Linking (static and dynamic) --
Operating Systems: Classical concepts (concurrency, synchronization, deadlock), Processes, threads and Inter-process communication, CPU scheduling, Memory management, File systems, I/O systems, Protection and security.
Databases: Relational model (ER-model, relational algebra, tuple calculus), Database design (integrity constraints, normal forms), Query languages (SQL), File structures (sequential files, indexing, B+ trees), Transactions and concurrency control --
Computer Networks: ISO/OSI stack, sliding window protocol, LAN Technologies (Ethernet, Token ring), TCP/UDP, IP, Basic concepts of switches, gateways, and routers.
